November 27, 2024, 02:00:24 pm *
Author Topic: 0.9y4 - Problem with restart of services  (Read 14479 times)
0 Members and 10 Guests are viewing this topic.
earflappin
« on: November 07, 2009, 06:21:56 pm »
Peter, continue to love the 0.9y4 release with QARC.  Best sound by far I've heard.  I particularly have found the Q settings very helpful.
I've come across two issues with 0.9y4 under Windows 7 64 bit.  Once I have run XXHE and then shut it down, I
(1) Lose the Windows 7 Task Bar and
(2) Cannot initiate another Remote Desktop Connection (RDC) session.
Pushing the "services" button on XXHE does not remedy the situation.
I don't recall having these issues before I "tweaked" Win7 using the Vista info on your forum.  Unfortunately, I failed to create a restore point before making those changes!  So...I'm reinstalling Win7 now to see if the tweaks were the issue.
I'll report back more later.
« Reply #1 on: November 07, 2009, 07:22:56 pm »
Maybe try restart the service "Remote Desktop Configuration"
Or did you already re-installed W7 ?
Roy
« Reply #2 on: November 07, 2009, 07:30:44 pm »
And on the toolbar,
try hit the Windows-button or rightclick were the toolbar should be.
earflappin
« Reply #3 on: November 07, 2009, 08:30:42 pm »
Thanks Roy for the thoughts.  I reinstalled Win 7 64 - so no tweaks, just standard RDC - and ran a number of repetitive test to pinpoint the symptoms.  The problem of the Task Bar not reappearing after leaving unattended mode went away.
The RDC problem remains.  Here's what happens.
+ Logging on and off with RDC works fine after music server boot up.
+ If you just start XXHE and do not initiate play - you can log on and off with RDC with no issues.
+ As soon as you hit play OR stop running XXHE - you cannot log on again with RDC.  This when the "stop services" flag is not checked as well as when it is checked.  Logging on locally to the music server (with a connected display and keyboard) and clicking the "services" button does not solve the problem.
+ The only solution is a system restart.
=> Been too long since I wrote code, but it would seem services associated with RDC are being turned off when XXHE goes into play mode...and not reset.  However, since the problem doesn't manifest until you hit play, but also shows up when you quit the program without having played a song indicates a more complex interaction.  I will leave that to Mr. Peter....software guru.
+ Also, HotKey will not work after start-up unless you click on the HotKey short cut on the desktop and "run it".
I'm now using Task Manager to see if I can locate what services might be getting shut down that is causing this issue.
« Reply #4 on: November 07, 2009, 08:55:36 pm »
Just put AHK (xx.ahk) shortcut it in the startup folder (optional: together with shortcut of xxhighend.exe)
C:\users\(your namexxxxxxxxxxx)\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\startup
And all will startup automaticly.
Next step:
You also want to look at this (its about removing the xx.ahk (sometimes annoying) message at startup)
http://www.phasure.com/index.php?topic=753.msg6655#msg6655
Roy
earflappin
« Reply #5 on: November 07, 2009, 09:01:28 pm »
Okay....another symptom.
I have hotkey installed.  As I said, after each music server boot up I have to run the short cut to get hotkey to work.  So I deinstalled hotkey.  Now the other problem I mentioned showed up again.  If I run XXHE in unattended mode, sometimes (not every time) when it stops playing and the program window reappears if you close out of the program the Task Bar will not reappear.  It's intermittent.  In that scenario I have to reboot XXHE and then stop out of it again.
« Reply #6 on: November 07, 2009, 09:09:28 pm »
Sometimes it can be better to install the program itself look here:
http://www.autohotkey.com/download/
install program
let it work with xx:
http://www.phasure.com/index.php?topic=724.msg5220#msg5220
read my previous message carefully, to do all automaticly
And the rest you have to sort out with Peter, not my cup of tea, indeed !!
« Reply #7 on: November 07, 2009, 09:25:25 pm »
Maybe under "taskbar and startmenu properties" options tick "Lock Taskbar"
(so rightclick on the windows logo, hit properties)
maybe this helps to keep your taskbar
« Reply #8 on: November 07, 2009, 09:55:57 pm »
Hi David,
I could try to go in whatever detail, but right now the thing to tell you really is that I do not touch a single thing regarding your RDC issue. However :
Can it be so that during playback you received a message about a "Service stopped working" ? This is not uncommon at all (everybody experiences this) BUT it is not the intention that mr. W7 in your case shuts down services you are using/needing. Remember, if this indeed happens to you, this it *not* me doing that.
Before proceeding, please let me know about this.
In the mean time, if you indeed receive such messages from the OS, it is my estimate that putting the thread priority more towards "normal" will help. Notice though that this is *not* the solution in the end (sound will get worse from it).
earflappin
« Reply #9 on: November 07, 2009, 10:21:18 pm »
Thanks Roy and Peter.
I'll investigate the RDC issue further.  Good to know that XXHE isn't turning off any of the RDC related services.  What's weird is that I don't remember having this issue from the beginning...oh well, it's not that big of deal anyway.
Regarding the Task Bar issue....it doesn't happen if I stop play BEFORE quitting XXHE.  In other words, if you run XXHE unattended, then bring it out of unattended by Alt-X and then either hit the "off" or just close the XXHE window via the "X" in the right hand corner....then the Task Bar will not reappear.
It appears in the code there is not a command to restart services unless the stop key has been pressed OR all songs in the playlist have been played first....weird thing is that even if I hit the "services button" before exiting XXHE via either the "Off" or "X" means I still don't get the Task Bar back....and if you open a folder it's clear that the window graphics have been dumbed down....i.e. it looks like what you get if you go into System settings and select "optimize for performance" versus for appearance.
This is no big deal as now that I know about it all I need to do is to hit stop before I exit....
Regarding RDC....I figured out the issue!  If you set the Processor Core Appt Scheme to any of the schemes (1-4) you can't re-establish RDC....  This is why I remembered it working before because I didn't start off with the Scheme selected...
Any ideas on how I might work around this issue....it would appear RDC wants to have access to both cores....  If not I'll just live with it as is....I definitely am looking for the best SQ, it's just that the way I have to have my listening room set up I can't practically have a monitor/keyboard/mouse connected....  and stay married anyways...   Wink
« Reply #10 on: November 07, 2009, 10:47:36 pm »
This problem will remain, for all of us, unless somebody comes with a decent remote option.
That does not influence SQ, but sure functionality is also a big issue, just keep the RDC.
Did not try this myself, I only have 1 PC, for know.
We just wanted to report you about the disadvantages of using RDC. (vs SQ)
But is should be possible, to do this the right way. (with using 2 PC's)
« Reply #11 on: November 07, 2009, 11:05:06 pm »
I'll be looking into that Core Appointment issue ! Thanks for finding this all out, David.
Well, I am the most sure combinations exist that the taskbar won't reappear, but this as sure doesn't look like one of them. I mean, your description just denotes "keep on playing my boy", and the taskbar *should* stay away. However, at Alt-X it should reappear in the first place (and it sure  does here -> Vista), while quitting XXHighEnd should let it disappear again.
Please read your own desription carefully, as well as mine, because both imply a different situation, and to me it looks like your decription is not correct. Both though, just *should* end up in "no taskbar" ! (so it is also a matter of understanding how the principle is set up ?)
earflappin
« Reply #12 on: November 08, 2009, 12:52:13 am »
 oops
My bad!  It just dawned on me that unless you hit stop the Engine 3 thread will continue to run...and the services which were switched off will stay off....   WTF !
Nevermind.... Happy
« Reply #13 on: November 08, 2009, 01:21:06 am »
Page created in 0.369 seconds with 19 queries.
