Marcin_gps
« Reply #135 on: June 13, 2010, 03:40:07 pm » |
I just wanted to say that Cantatis released new drivers for Overture sound card. I'm sitting jawdropped. You may ask why? I'll tell you. So far, I haven't been able to go below 1024 samples in adaptive mode and now I'm playing at 32 samples and Q1=-4 with QAP - no clicks  Why am I writing this? To confirm my previous hypothesis, that drivers' performance is the most important thing when it comes to low latency playback. Of course, Peter knew that before
Marcin_gps
« Reply #136 on: June 25, 2010, 12:21:06 am » |
I've just flashed my Cantatis Overture sound card to Audiotrak Prodigy 7.1 hifi and it's working! Native ASIO drivers and KS work, even with 48 samples, There is one problem though:
- 44kHz (88,2,176) playback works, 48kHz (and multipliers that is 96,192) don't work properly. It's like listening to music in 'slow motion'. I guess that Prodigy 7.1 hifi has different clock on board for 48 and its multipliers.
I'd be very greatful if someone with Juli@ card could take a picture of EEPROM offsets. Juli@ has the same clocks as Cantatis, so my assumption is that it'd work for 48kHz playback as well.
* In order to do so, you need to run eeprw.exe (enclosed) in 'real' DOS mode, press 9 and take a picture of Juli@'s offsets. That's it, it'd take few seconds. (enclosed you will see EEPROM for Cantatis. I need offset values for JULi@)
* Note that eeprw works only under 'real' DOS mode, you can't run it from windows. In order to run DOS, there is a tool called HP USB Disk Storage Format Tool + win98boot files (enclosed). With these 2 things you can prepare bootable usb flash. After a 'start disk' is created, copy eeprw to your flash drive, restart pc and boot from it.
Thank you in advance for help, Marcin
« Reply #137 on: June 25, 2010, 12:32:44 am » |
Hold on.........
« Reply #138 on: June 25, 2010, 01:08:49 am » |
Here you are..............
Marcin_gps
« Reply #139 on: June 25, 2010, 01:26:41 am » |
Roy, you're the best! THANKS
Marcin_gps
« Reply #140 on: October 26, 2010, 04:15:26 pm » |
Guys from Cantatis finally gave me some valueable tip  I don't use their control panel, because it doesn't work in W2008 at all. I installed the drivers only. This is very simple tweak and for me - a life saver!!! What you need to do is: Search for the following registry keys in regedit: VA_CPLAutoSR (set to 0 = no auto sample rate, 1 = auto sample rate) VA_CPLSelectSR (set as follows, in hexadecimal, I set to 0x0e that is 192kHz): 0x00: 48 KHz (default) 0x01: 24 KHz 0x02: 12 KHz 0x03: 9.6 KHz 0x04: 32 KHz 0x05: 16 KHz 0x06: 8 KHz 0x07: 96 KHz 0x0E: 192 KHz 0x0f: 64 KHz 0x08: 44.1 KHz 0x09: 22.05 KHz 0x0A: 11.025 KHz 0x0B: 88.2 KHz 0x0C: 176.4 KHz Now I don't have to change the damn thing every time I want to listen to some different sample rates stuff. Enjoy! Marcin
Leo
« Reply #141 on: October 26, 2010, 05:04:02 pm » |
Nice !
Leo
Dedicated silent audio pc HFX classic, Windows 8 pro 64bit / Intel 3930 CPU 6 cores 12 threads, ASRock x79 Extreme4-M/ SeaSonic Platinum 400w ATX PSU / 16Gb RAM , music on (SATAIII), MinOS/ Engine#4 Special Mode / Q1/2/3/4/5 = *6*/0/1/1/1 Qf=1 (Dev.Buffer = 4096) / not Invert / Playerprio = Low / ThreadPrio = Real Time / *Scheme = 1-2* @ UnAttended /Services Off + No Running Time / Octo Arc Prediction Upsampling / *SFS=0,4 max= 120* XT Tweaks balanced load 43, nervous=100, cool when idle 1, Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Double Octo Arc Prediction Upsampling / -> USB with Dexa clock -> 24/768 Phasure NOS1 async USB DAC, Driver v1.0.3 (2ms) -> direct to AMP: Gainclone mid high, Hypex DPS400 low, horn system (tractrix for mid/high, BD for bass with Oris200)
