November 24, 2024, 01:04:35 am *
Author Topic: Minor quirks in 9a  (Read 26781 times)
Chris V
« on: June 26, 2007, 04:31:02 pm »
Hi Peter
The words 'double', 'upsample' and 'gapless' all spill over onto 2 lines, making the visual presentation a bit scruffy Happy
Cheers Chris
Then to SW1X Signature DAC
« Reply #1 on: June 26, 2007, 04:35:05 pm »
Huh ?
What OS etc. ?
Can you post a screencopy, Chris ?
Chris V
« Reply #2 on: June 26, 2007, 04:50:07 pm »
I've seen this also on one or two earlier versions.
This is on my Vista laptop, with screen set at 1280x800.
I would love to do a screen copy but cant find how unhappy
« Reply #3 on: June 26, 2007, 05:16:51 pm »
Shift-printscreen and paste to a Word document would be one way ... (not the best, but it's a way).
Chris V
« Reply #4 on: June 26, 2007, 05:33:36 pm »
Holding down shift key and then hitting 'print screen' does nothing on any of my 3 PCs unhappy
« Reply #5 on: June 26, 2007, 05:43:46 pm »
O yes, it does ... Btw. Alt-Printscreen would be far better. It makes a copy of the active window.
So ...
Click on the window you want a copy from. - Press Alt-Printscreen.
Open a Word document. - Click on the text area, and press Ctrl-V.
Now please don't tell me that nothing happens ! because there just should ... aggressive
Gerner
« Reply #6 on: June 26, 2007, 06:14:44 pm »
So ...
Ehh didn't try on vista, but on XP and W2000 you have to: Alt-printScrn-Insert. So 3 buttons to hit. Then paste it into whatever.
Gerner
Troubleless playback.
« Reply #7 on: June 26, 2007, 06:54:55 pm »
So ...
New to me ... (and btw not true here Happy)
Gerner
Chris V
« Reply #8 on: June 26, 2007, 08:27:02 pm »
Nearly there.
I have a copy of the screen as a Word document, but how do I post it here. I dont think I can link to my PC!
Cheers Chris
« Reply #9 on: June 26, 2007, 08:38:07 pm »
USB Stick ?
Floppy  teasing
Make a photograph ? teasingteasing
Chris, I didn't know that now *this* would be your problem. sorry
Did you perhaps tell your PC to use enlarged fonts ?
Are these the only two fields which wrap to a next line ?
And do you have this in Vista as well as in XP ?
Does anyone else see this ?
Chris V
« Reply #10 on: June 26, 2007, 09:20:10 pm »
I will keep trying to find a way to post.
These are the only fields that wrap around
My PC is set to medium font. (I think)
I see this on both my XP desktop and my Vista laptop
Cheers Chris
Chris V
« Reply #11 on: June 26, 2007, 09:48:25 pm »
Sorry Peter
But neither me nor the wife (who is quite good at this sort of thing) can get the copy of the screen out of the word document and into a picture like a JPeg.
If you are desperate to see it, the only way would be to let me have your e mail and I will send it as an attachment. I know you don't want your e mail addy out too much in the public domain so I will understand if you don't want to do this. friends
« Reply #12 on: June 26, 2007, 10:19:25 pm »
Hi Chris,
Is it possible that you've resized XX (like you can resize a window)? If made too small then things do overlap in XX...
Try to make it larger to see if it then looks okay?
« Reply #13 on: June 26, 2007, 10:33:58 pm »
Somehow this is related to having set the Classic (Windows2000) style, *or* this just is Windows2000.
I will try to copy this behaviour, and then try to solve it.
And Chris, If I'm right on my assumption, did you set this Classic style on purpose ? ?
Chris V
« Reply #14 on: June 26, 2007, 10:36:32 pm »
I wish I was that clever Wink
Nope it just happened somehow wacko
Page created in 0.198 seconds with 19 queries.
