November 23, 2024, 07:06:41 pm *
Author Topic: What hapens with my licens if....  (Read 7237 times)
Flecko
« on: June 26, 2007, 02:15:42 pm »
.... I like (must) to reinstall my system?
.... I like to use anohter pc as main-audiopc?
.... I like to replace the old audiopc by a new one?
Do I have to buy a new licens if one of these things happens or can I reinstall a main version?
How often may that happen until I don't get a new mainversion?
Perhaps in one or two years one of the upper cases will happen (probably more), so is there a confirmation that I have bought a licens?
Greetings Adrian
« Reply #1 on: June 26, 2007, 03:40:07 pm »
Adrian,
1. You just can do it again (Activate).
2. On this other PC you can enter the path to the "original" PC and location (as described in here Activation ... How ?).
3. That might be a problem, depending on what you changed on the new PC. Anyway, in here I I also talked about that, and in the end you will always be ok.
Since it's my feeling that number 3 above must be solved by some means of automation, number 2 (I think) can be solved by the same means to avoid the awkwardness of that.
I hope this gives you a more or less good feeling. Happy
