November 27, 2024, 08:48:21 pm *
Author Topic: Does XXHE work on Windows 7 o/s?  (Read 9329 times)
« on: October 13, 2009, 10:40:29 am »
Does XXHE work on Windows 7 o/s & if yes anything to be done differently than Vista?
« Reply #1 on: October 13, 2009, 10:44:19 am »
Hi Arvind,
Yes, quite some people are using it for a long time already (like over 6 months).
The only thing I wonder myself is whether the Wallpaper will work without additional settings in the OS, just because there was some discussion about that, and I don't think I ever saw the final solution, and whether it was user error to begin with. But anyway it can be solved (can be worked out with those using W7, which btw is not me, yet).
« Reply #2 on: October 13, 2009, 04:07:12 pm »
Hi Arvind,
Yes, IIRC the wallpaper has to be set as tiles, otherwise it wont work.
Besides this xxhe works in w7 exactly as in vista.
Eric
« Reply #3 on: November 11, 2009, 04:31:58 pm »
Who knows if it makes a difference to choose W7 x32 or W7 x64?
Any recommendations?
Does XXHE perform on both?
Cheers, Eric.
earflappin
« Reply #4 on: November 11, 2009, 08:03:35 pm »
I tried both Win7 32 and 64 bit and didn't notice a difference in SQ.  XXHE works on both.  Personally, I'd go 64 bit if your HW allows it.
Eric
« Reply #5 on: November 11, 2009, 08:54:59 pm »
Thanks, that is the plan but first I wanted to be sure that XXHE works!
Page created in 0.119 seconds with 19 queries.
