November 23, 2024, 01:07:35 pm *
Pages: 1 2 [3]  All
Author Topic: Help me find a new DAC  (Read 51512 times)
« Reply #30 on: October 27, 2009, 04:46:41 pm »
My experience says not to use an extra soundcard, but I guess depends on hardware (PC/DAC) and cable
For me its the other way around, I really need a soundcard, I did some listening a couple of months ago, The onboard sound device is really horrible, dead, no dynamics, boring. (also Gigabyte)
I'am still on a Toslink, will modify my soundcard next week, and try a coax (I have good experiences with the coax Belden 1694A or use the 1505A)
Toslink and xx always sounded "good" to me, so there was no rush to "upgrade" to coax.
But I have the parts still laying around.
Nice to see people playing around with the Hong Kong DAC, its that cheap, so why not.
Good choice
Grtz
« Reply #31 on: October 27, 2009, 06:11:38 pm »
Hi Leo,
Well i had the pleasure to receive a package from Hong Kong yesterday...  Happy
And have been very busy with it... I use the usb from the dac. At the moment i can only use Double an Quad. But no 24 bit and so no ARC. That does not work at the moment. I am thinking about a new soundcard with a spdif output.
Maybe that is the trick....  Grin
About the sound.... There was a day that Peter told that the album from Ibrahim was his favorit... So i bought it.... I thought that Peter has a very bad taste... rofl rofl
But now i understand why.... It now sounds like a piano.... So Peter sorry for that.... Wink
The 100 euro is well spend and i still have the spec mod to go like GerardA....
Grtz Gerard
« Reply #32 on: October 27, 2009, 07:26:36 pm »
rofl
So, how did it sound before ? (I am really curious)
« Reply #33 on: October 27, 2009, 07:34:14 pm »
rofl
I like piano too... but only if it sounds deep... The piano before sounded flat... Like the low notes do not come out the piano. And now the notes sounds seperate from each other.. it is not easy to explain but i like to feel the piano... befor it did not with this cd... I am sure it will be much better with your DAC.... But this makes me happy now....  Happy
Grtz
Leo
« Reply #34 on: October 28, 2009, 12:09:04 am »
Well I have the new DAC playing now in 44.1 (works with its own usb, a Trends usb converter and fireface 400) and 88.2 which only works with spdif from the fireface. The 192 option with quad upsampling in XX will only produce very, very low level sound like crosstalk from a not chosen input in an amp.
The Altmann dac however does work on 176 (with just the 16 bits) from the fireface, another riddle to be solved I guess.
Even in unmodified form this new DAC sounds very nice, so thanks for the suggestion to look into this one. Tomorrow I will have to decide whether to hunt further for the quad upsampling or heat up the iron for modification.
I do hope you realize Peter what kind of heavy decision making all this waiting for your DAC is causing in once peacefull and content homes !
« Reply #35 on: October 28, 2009, 10:35:56 am »
Well have send a email to Hong Kong yesterday.... They say that USB do not deliver 24 bit. Only the COAX and the OPTICAL does that.
That makes it easyer.... Happy
Now search for a new soundcard....
« Reply #36 on: October 28, 2009, 12:30:43 pm »
Not..... Fixed my problem with the EMU 1212m... That now does deliver 24/192 spdif... So my Hong Kong dac now can do Arc Prediction.  Happy
Happy man overhere... Save's me 120 Euro.....  Happy
« Reply #37 on: October 28, 2009, 12:53:56 pm »
Haha, good. If you're only tempted !
Pages: 1 2 [3]  All
