November 23, 2024, 06:34:18 pm *
Author Topic: Delete File's  (Read 14253 times)
« on: September 21, 2009, 04:03:33 pm »
I have a problem..... :-(
Ok i thought i could get rid of my mp3 albums that are mixed up with my WAV Collection.
But i would like to keep them. So i thought that first make a Physical copy of them before delete them with xx.
Searching for them results for 90% off the attempts in a black screen. Sometime's it gives the results, but than when i like to copy them XX stops after a few albums. So i thougt lets do it in steps. I checked the checkbox and checked the first 16 mp3 albums. Copy those worked. After that i thought delete them right away while the checked albums are already checked wacko
But when i used the delete function not the 16 mp3 albums where deleted but my whole collection! unhappy In a eye blink it was gone)
So two things do not go right.
1: The search option for searching does not work (here)
2: Deleting a selection results in a total delete of my collection. (strange thing also is that XXhighend now starts in Demo mode) No now i see that everything is gone on my D:drive.... Also the XX code  unhappy
grtz Gerard  Happy
« Reply #1 on: September 21, 2009, 05:04:14 pm »
Uhm, Gerard, this looks serious enough to deal with in our normal dutch, while I must be able to do that anyway.
Anyway I don't see any normal way that would allow to delete everything without further notice. The coding is just not there !
So for your conveniency, start sending me an email in dutch. I don't know exactly about what ... maybe your current judgement about what happened to your drive D:, assuming that this is not where your music normally resides.
You can do it in here just the same if you like that better.
« Reply #2 on: September 21, 2009, 05:26:21 pm »
Hoi Peter,
Ik weet niet wat ik er meer over kan zeggen maar op een paar mappen na is alles weg. De map met XX was voor een deel weg. Ik had het eerst niet door tot ik XX opnieuw wilde opstarten. Hij gaf toen aan dat deze in demo mode was. En een kijkje op de D: waar mijn collectie en de map van xx opstond gaf aan dat deze nagenoeg leeg was. De map met XX was voor een deel weg vandaar ook de demo mode die hij na deleting aangaf.
Ik zou je graag een paar foto’s sturen maar voor mijn Backup er weer opstaat dat duurt even. En om het nog een keer te doen….. Haha… Voor jou ook niet echt leuk om proberen….. Ik wilde dus mijn mp3 collectie weg hebben van het goede spul….. Zoeken naar mp3 albums gaat bijna niet. Het grootste deel van mijn zoekactie eindigde in een zwart scherm. Soms lukte het toch om alleen mijn mp3 albums zichtbaar te krijgen. Dit deed ik door Mp3 in te toetsen onderdaan. Maar alles ik een keer copieeren lukte niet. Dit eindigde in een paar error meldingen. Ik wilde dus mijn mp3 deel eerst ergens op de C:\ wegzetten en daarna de geselecteerde Mp3 verwijderen met XX.
Ik heb er toen eerst 16 geselecteerd door ze aan te vinken. Die 16 copieeren werkte goed. Maar toen ik daarna op delete drukte via rechtermuisknop Toen ging er iets niet goed. Zelfs geen melding of ik het zeker wist of iets….
Dus toen was alles weg.  Happy
Grtz
« Reply #3 on: September 21, 2009, 05:40:38 pm »
Is op D: nou echt alles weg behalve een stukje XX folder ? Nee dus, maar welke mappen zijn er nou nog ?
Terzijde (misschien) Deleten via de Checkboxes is niet eens gemaakt (zoals er zo veel niet via de checkboxes werkt). Maar ik zal in elk geval eens kijken wat er dan eigenlijk gebeurt ...
Voor de zekerheid, de optie die je beneden ziet is degene die je hebt gebruikt ? (ik heb mijn checkboxes maar even weggelaten oops)
« Reply #4 on: September 21, 2009, 05:44:08 pm »
Hoi peter,
Alles is weg op de D:\500 GB Behalve een deel van de xx folder. (Mischien omdat XX in gebruik was.)
Ook in de Prullebak is deze niet te vinden.
Dat is inderdaad degene die die ik gebruikt heb.
Succes..... ;-)
« Reply #5 on: September 21, 2009, 05:47:40 pm »
is het niet veiliger als xx bestanden verwijderd,
om ze naar de prullebak te zetten, ipv permanent te verwijderen
sorry voor het onderbreken Wink
« Reply #6 on: September 21, 2009, 05:52:51 pm »
Nou lekker zeg ... Dus een funkionaliteit die ik *niet* heb gemaakt zou alles weggooien ?? toch knap.
Maar niet leuk.
Hoe zal ik dit eens testen hier ... scratching  Happy Happy
Er vooralsnog vanuitgaande dat het aan mij ligt ... sorry hoor !!!
Maar toch even ... (want ik durf nu zelf even nauwelijk), toen je op die optie klikte kwam er helemaal NIETS naar voren van een vraag of zo ?
Ja natuurlijk, maar dat blijkt onmogelijk. D.w.z., ik heb dat geprobeerd zo te maken, en ofschoon de funktionaliteit bestaat (VB.NET) is er geen middel om
a. in meerdere folders tegelijk te werken
b. wat ik wel kan simuleren, maar niet kan worden teruggehaald naar die folders (dus, het zou 1 grote stapel worden waar je niets meer mee kan).
Ik heb er nog aan gedacht om zelf een prullenbak te simuleren, maar dat werd me te moeilijk. En dus heb ik er maar voor gezorgd dat je zo goed mogelijk ziet wat je doet. Eh ... als je geen checkboxes gebruikt.
« Reply #7 on: September 21, 2009, 06:10:18 pm »
Maar niet leuk.
 rofl unsure
Er kwam inderdaad helemaal niets.... Als je het probeert na te doen zorg dan dat XX  op de harde schijf staat die je muziek collectie bevat. Anders is je Windows gedeelte mischien wel weg.
En mischien iets als knippen/plakken te maken.
« Reply #8 on: September 21, 2009, 06:36:44 pm »
Nou, ik heb het net heeel voorzichtig nagedaan (nadat ik het werkelijk command wat de zooi weggooit toch even had weggesterd), maar dit is wat er gebeurt :
Ik selekteer - via de chechboxes dus - 2 albums. Vervolgens wordt 1 niveau HOGER geselekteerd. Jaja, dat kan dus de root zijn ...
Alleen, hoe ik het ook wend of keer, daarna toont onderstaand schermpje dat niveau hoger (in mijn geval dus G:\MP3\PS), en als ik nu op Delete click zal alles wel weg zijn ... (default is skip, dus per ongeluk Enter kan eigenlijk ook niet).
Goed, dat heb ik ook nog even gedaan, en vervolgens gaat de boel nòg een niveau hoger de deur uit !! In mijn geval dus G:\MP3.
Jammer ...
Ik weet niet wat ik zeggen moet, behalve dat je dat schermpje (zie onder) toch echt had moeten krijgen.
Ik begrijp dat je gelukkig een backup hebt ...
Alles maar even samengevat : Deleten via de Checkboxes is nooit gemaakt, maar doet per ongeluk wel wat, omdat als je rightclick doet op een Item, dit is geselekteerd en dus de funktie vanzelf wordt geaktiveerd (welke je ook kiest). Vervolgens klopt er geen bal van, omdat het selekteren via checkboxes (is gewoon MS funktionaliteit -> kan in Explorer ook als je het nog niet wist) heel anders loopt van binnen.
Ik zal het ook nog in het Engels samenvatten voor de rest ...
« Reply #9 on: September 21, 2009, 06:45:35 pm »
Jammer ...
Gelukkig heb ik een backup inderdaad. ALs alles er weer opstaat zal ik het nog eens doen... Zal ik gelijk ook de errors posten die opkomen als ik de selectie wil kopieren.
« Reply #10 on: September 21, 2009, 06:48:32 pm »
Nou, doe maar liever niet !
For others, this sums it up : http://www.phasure.com/index.php?topic=926.0
