« on: September 05, 2009, 11:00:51 pm » |
Are the volume change errors fixed? I didnt read about it in the release notes. Since yesterday is getting worse, basically any change of volume incurs to an error and i have to restart xxhe to be able to play.
I have logs that i can copy or send u.
« Reply #1 on: September 06, 2009, 03:13:59 pm » |
Hi Telstar, I am sorry (maybe ) but I didn't change anything. Why ? I asked you questions about this (other topic) but you never responded. Maybe you can find it yourself, paste it in here, so we can work it out. If something is not in the Release Notes, it has not been done (well, that's how it should be). I have no problems with the volume whatsoever. But then I use it how it should (as explained elsewhere), which may not be what you do. Again, you didn't respond or explain. Thanks, Peter
« Reply #2 on: September 06, 2009, 05:09:44 pm » |
Hi Telstar, I am sorry (maybe ) but I didn't change anything. Why ? I asked you questions about this (other topic) but you never responded. I must have missed it and now cant find that topic. That's why I made this one Will play something later this evening and send u the log and as well the conditions which triggers it.
« Reply #3 on: September 06, 2009, 07:06:35 pm » |
All of yesterday I was using volume and don't recall ever having errors doing so. Hope it works out for you Telstar edit I do go real slow. (AHK) push alt U/alt D ...wait for vol to change... then push again.
0.9z-8-3a WAV/CUE files on HDDs via MB FW400>; Win7 pro ttp://www.phasure.com/index.php?topic=352.msg4021#msg4021); [XXHighEnd player Qs 7, 0, 0, 0, 0; eng 4; adaptive; scheme#3; player priority low; thread priority realtime; clock res 5ms: SFS 420 dac is 24/192 w/32bits; Play Unattended; Stop Services ticked; Wallpaper & Show Back ticked - Mirror Image unticked; Start Engine unticked;garbage collect ticked; copy files to XX-drive; *quad arc prediction upsampling*: straight contiguous:>PCI FW800 card>Fireface 800 DAC [latency 2048 samples for 176.4]; usb/ethernet/mb audio shut off @ MB
« Reply #4 on: September 06, 2009, 07:40:20 pm » |
I must have missed it and now cant find that topic. That's why I made this one Hahaha, almost correct ! You can't find the "topic" because it was posted in the middle of another one, which ... you just did again. I mean, it was me creating this as s "topic" for you (and myself ), which only indicates the relative importance of specific problems being in their own topics. http://www.phasure.com/index.php?topic=82.0 Anyway, if you can describe what you do, I will try to solve it. That's about time anwyay (because it is not fool proof at this moment ... not calling you that fool of course ).
« Reply #5 on: September 07, 2009, 02:13:50 pm » |
I must have missed it and now cant find that topic. That's why I made this one Hahaha, almost correct ! You can't find the "topic" because it was posted in the middle of another one, which ... you just did again. Did I? Dammit. I have lots of things on my head and I'm listening to less music that O wanted. And that relaxes me... Note that I use the mouse to change the TINY volume slider and that I hold it until i read the number i want on the left. For the errors themselves, i'll post screens and logs later tonight.
« Reply #6 on: September 15, 2009, 02:40:24 pm » |
Yes, if you have the files (XX and X3) from that error, that might be useful. The previous time (that was that first email I think) of course was not much useful, because then it worked. What does this mean? "because then it worked"? In the logs i sent you the crash error happened two times. I guess it doesnt show. It is RANDOM and happens like 1/10 of the times when i'm changing volume. But stuff it in the topic please (and there please explain carefully what you did), or I'll get crazy. OK, i'm posting here. But I think i explained it several times Once more: With the MOUSE pointer i went on the volume slider of the ATTENDED window and changed i.e. from -15 to -10.5. Pof!Since last week, I haven't had the pleasure to listen to much music since then. Yesterday i had a couple hours and got the error again. What I can say more is that I think it didnt happen with x- versions. and I think is due to timing/latency. If you fix the "change volume several times in one second" bug, MAYBE also my issue will be gone. Not sure if u did Besides, I still have the start menu logo to disappear bug. I dont care much anymore since i have the bar hidden on the music pc, just FYI. XX and X3: you mean the .dat files? Version is y-3 +3a exe. In the attached zip are ALL the files which have date of yesterday at about the time of the crash (except the wallpaper).
« Reply #7 on: September 15, 2009, 03:32:46 pm » |
Hi Telstar, I can't be sure what is going on with you, but to me you seem to be more and more confusing. I TOLD you not to use that mousewheel. Or did I not ? Or did I tell you I fixed that ? Instead you again create a post for it (which now has become this thread). Next I ask you for the details : Anyway, if you can describe what you do, I will try to solve it. and next I receive nothing. Oh yes, I received an email with in there that you were not able to let it go wrong anymore. In the logs i sent you the crash error happened two times. That may be so, but see my last sentence. I obviously did not look in the log files because you said you couldn't let it go wrong (leaving me in wonder what to do with those log files then). Did I maybe read it all wrongly ? perhaps, and in that case I am very sorry. But why sending me emails about this is in the first place ? Here is your topic about it ! Then I recall - previous to this topic - you started this subject two times earlier, with similar result. OK, i'm posting here. But I think i explained it several times Once more: With the MOUSE pointer i went on the volume slider of the ATTENDED window and changed i.e. from -15 to -10.5. Pof! I don't think you listened much to what I said as many times about it. If you do this in one go (and it was YOU who suggested how to use it : at letting the mouse button go it will be effective) there is no problem. Well, I don't see you write anything special, with my conclusion that you did not work according this "prescription". So, I aksed you what you exactly do, and with this answer I cannot do anything. What are you up to, besides bombarding me with the same from many angles, BUT now leave out this which you did mention in the PM : I suspect it may be related with timing/latency and maybe with the VST host that I use, Console.jp At last that looks like important information. Why leave it out now, and instead come up with some less nice sentences and the wrong smileys ? Btw, your log files indeed show "something"; I'm not sure yet whether I can make anything of it. Right now I'm not even sure I WANT to make something of it. Not without your very precise description of what you do. In here please. Thanks. PS : For the next time : The log files are those in the TemporaryData folder (subfolder of your current XX folder). But of course I've got them now too as part of the larger set you posted.
« Reply #8 on: September 15, 2009, 04:12:29 pm » |
Hi Peter, Sorry for the tone of my last post. I think there has been a huge misunderstanding from both parties. I TOLD you not to use that mousewheel. Or did I not ? Or did I tell you I fixed that ? I didnt use the mousewheel, i dragged the mouse to move the slider. I have always done like this to change the volume. So, I aksed you what you exactly do, and with this answer I cannot do anything. I thought it was clear The thing about the mousewheel was a suggestion, it wasnt and it's not related to the crash. What are you up to, besides bombarding me with the same from many angles, BUT now leave out this which you did mention in the PM : I suspect it may be related with timing/latency and maybe with the VST host that I use, Console.jp copy and paste mistake, sorry. Btw, your log files indeed show "something"; I'm not sure yet whether I can make anything of it. Right now I'm not even sure I WANT to make something of it. Not without your very precise description of what you do. In here please. This is what i do to change the volume: With the MOUSE pointer i went on the volume slider of the ATTENDED window and moved the mouse to change it from -15 to -10.5. Or to a different step. Higher or lower crashes anyway some times.Is the description clear and precise now? I dont know what else to say to explain it PS : For the next time : The log files are those in the TemporaryData folder (subfolder of your current XX folder). But of course I've got them now too as part of the larger set you posted. I copied everything beause from the logs I sent you with email (another misunderstanding with the error gone, it just didnt happen the next day, didnt mean it was gone) thought they werent enough to show the issue.
« Reply #9 on: September 15, 2009, 05:24:42 pm » |
Is the description clear and precise now? I dont know what else to say to explain it Of course this by itself is clear. But the (or my) point is that this looks too simple. I use it countless times per day and never see a problem ? I know though, I shouldn't be using it right at the end of a track. Or, do it when a previous one is "pending" so to say. Thus, as said before, there sure are ways to let it go wrong, and it sure is time to solve it. But now, what is it what lets it go wrong with you ? Ok, I'll have a look in those log files, and see whether I have questions from there. One thing is clear : something must be solved.
« Reply #10 on: September 15, 2009, 06:04:45 pm » |
Is the description clear and precise now? I dont know what else to say to explain it Of course this by itself is clear. But the (or my) point is that this looks too simple. I use it countless times per day and never see a problem ? I know though, I shouldn't be using it right at the end of a track. Or, do it when a previous one is "pending" so to say. I change volume normally at the beginning of a track to adjust it to my desired level (somebody called me a volume freak, i take that as a compliment since I'm able to spot 0.3db changes). Also, I have "start xxhe during conversion" disabled. Thus, as said before, there sure are ways to let it go wrong, and it sure is time to solve it. But now, what is it what lets it go wrong with you ? I think that it has to do with the ASIO router and the timing (latency). It messes with something in xxhe ONLY with the volume change. I cannot do without until a XO is implemented in xxhe Ok, I'll have a look in those log files, and see whether I have questions from there. One thing is clear : something must be solved. Thanks. But no hurry, just really curious how the error is triggered. I thought you had forgotten bout it.
« Reply #11 on: September 20, 2009, 12:35:20 pm » |
Hi Telstar,
I could have told it a few days ago already (when I examined the log files), but this is not related to "volume change" as such, but more generally the manipulation of the cache. The Volume Change needs that though, so to you it will appear as "volume change" going wrong. Instead it can (or will) happen at any situation that allows a change to the playback settings, like changing the Invert settings (there aren't many more of these).
Unfortunately this is very tough to solve because it completely depends on the situation which happened "in the past", like in your case playing a couple of tracks, change the volume of one, play another couple, and change it again. I mean, it is sheer undoable to copy this (because each test may take an hour) so it must be solved in theory. I can also tell you that this particular thing happened to me two times in 4 weeks of time which (ok for me) is a reason by itself not to dive into it. Also please note it is exactly this I have been working on for over a month to get, well, right(ish).
With this I don't say it won't be solved, but I myself need loads of (log file) data in order to be able to (hopefully) see the line in it. So, if it happens to you don't hesitate to post the log files of it, and the more I have of them, the better it will be.
One thing though : At least the last time this happened to you, you got a rather normal and clear message about it which reads : Unexpected situation at Remote Command; Playback must stop If you just tell this, it saves me 90 minutes of looking for something you could have spent 5 seconds on (just tell it). So I not only want to know exactly what one does, but also exactly what one sees. In addition to that, I don't see the reason in describing such a thing as "an error", while an error has a description.
Ok ? Thanks ! Peter
« Reply #12 on: September 20, 2009, 03:09:45 pm » |
Ok ? Thanks ! Peter
Yep, i never touch invert. I called it error because the program crash with a red window and no sound (loud PRRRRRRR in my case thanks to the cr*ppy drivers). Next time it happens i'll write down what it says. I dont think it is always the same error, though. I'll take the logs as well. The random errors that dont happen frequently are the hardest to catch and to solve, i agree, but are also the most annoying to me because they give a feeling of instability, unreliability of the software. I used vista since RC, I know what that means
« Reply #13 on: September 20, 2009, 03:42:11 pm » |
(loud PRRRRRRR in my case thanks to the cr*ppy drivers). Like a constant repeat of the last buffer contents you mean ?
« Reply #14 on: September 21, 2009, 07:00:28 am » |
(loud PRRRRRRR in my case thanks to the cr*ppy drivers). Like a constant repeat of the last buffer contents you mean ? Yes, exactly. But this happens with any player i use when i stop or pause a track. It's some bug in the quartet asio drivers.
