November 23, 2024, 06:26:11 pm *
Pages: 1 2 [3]  All
Author Topic: 0.9-y3 Laidback now ?  (Read 45806 times)
0 Members and 10 Guests are viewing this topic.
« Reply #30 on: September 06, 2009, 06:45:04 pm »
gosh darn... am I ever going to get this right?
I think I was stuffing XXHighend.exe from either y-2a or y-3 into either the folder of y-2a or y-3
not
xxengine3.exe
sigh
ok I'ma go stuff what you just posted into a new folder of y-3....
right? yep that's what you posted ok here goes [from Peter "below 09.y-3a version of XXEngine3. You should paste that over your 0.9y-3
folder."]
so who knows what I was hearing yesterday.
Next topic of discussion
"Reading Comprehension
& Do I have it?"
« Reply #31 on: September 06, 2009, 06:47:21 pm »
For those who are bothered by this : you are not upsampling and using the AA checkbox, or ?
Just to answer this question.  No  But I have not tested it for a very long time.
« Reply #32 on: September 06, 2009, 06:59:07 pm »
You should NOT use the AA checkbox. It will make things more "quiet".
But I'm serious, don't.
« Reply #33 on: September 06, 2009, 07:38:44 pm »
Ok
I did this:
...09.y-3a version of XXEngine3. You should paste that over your 0.9y-3
folder...
Just finished and put on a song in the background, sounds fine; I'll listen closer in a bit.
but
Can you tell me exactly what you'd like me to compare it to?
edit (just saw your below post... will do that for today... yea easy stuff)
I think this is what Russ left off with:
"So for now, I will continue with my initial hybrid which consisted of the bug reduced GUI from 0.9y-3 combined with the Engine#3 from 0.9y-2(a)."
so I will make this up and see if I hear differences... until I hear back from you Peter what you might want me what ver you might want me to listen against.
I've left the Thumbnail Cache at 500
« Reply #34 on: September 06, 2009, 07:42:41 pm »
To "nothing" would be the most easy. It just should sound right. Or right "again".
Things are quite confusing currently. So, if you had complaints with 0.9y-3, this may take that away.
« Reply #35 on: September 06, 2009, 09:20:28 pm »
Been listening to; The Bad Plus (a small modern jazz combo I've been enamored with); Roy Orbison (96_24, absolutely tear wrenching music); Infected Mushroom ... hehe; The Weavers 96_24 (ol stand by).  I've been having a great time NOT worrying about SQ differences and really enjoying the music.  I think that means the presentation is top notch and I really do like what I'm hearing from y-3a.  Maybe someone will want to do the back&forth dance... maybe I will with the y-1d later, but maybe not... having too much fun today.  The heat/humidity is gone today; yesterday was way too hot and too much work,,, that I messed up on anyway... I'm looking for enjoyment today and I've found it with y-3a.
btw
so people don't get lost in this thread of where to find the 9-y3a engine zip... here is the link to Peter's post of where he put it:
http://www.phasure.com/index.php?topic=907.msg7215#msg7215
« Reply #36 on: September 06, 2009, 10:06:56 pm »
Infected mushroom, he
Nice!
All fine here too, with 9-y3a (Like Peter said)
No need in getting back on forth.
Its good just good, now
« Reply #37 on: September 07, 2009, 09:17:57 am »
 good good good I seem to be back on track again with SQ using the new engine. good good good
I did a short session of A/B'ing between my hybrid and this 0.9y-3a ( which is essentially the swap of the old engine from y-2 and this new one ), and came to the conclusion that I couldn't discern any readily apparent differences flipping from one to the other. It takes about 45 seconds or so to jump from one setup to the other, taking into account that AHK needs to close down and restart also, and as this time increases it gets harder to remember subtleties in the music you are trying to differentiate. Well it does for this 'ol brain .. LOL
So I'm happy to put this turn of events to bed and try and get consistent playback happening again.
I need to revisit those setting parameters I think as version Y's seem to warrant some changes. I'm still getting the occassional lack of music start after the GUI disappears ... sometimes I might hear nothing at all and sometimes I might hear the hint of an attempt to start, then silence. Occassionally it will cease mid album. During these moments of silence, if I Alt-X back to the GUI, then click STOP and PLAY, there seems to be a 50-50 chance it will play OK at the track it left off from.
Let me have a play for a while Peter before I trouble you any more ! It will give your hair a chance to return to normal colour also .. hehe
« Reply #38 on: September 07, 2009, 09:35:07 am »
Hi Russ,
Is it so that this actually never went away ? I mean, you mentioned this before (a few weeks back), then at some stage reported all was back to normal. Although "all" was about quite some things back then, I thought you meant this one as well.
Not ?
« Reply #39 on: September 07, 2009, 10:37:51 am »
I made a new topic for this : Playback may start with ... silence.
Pages: 1 2 [3]  All
Page created in 2.001 seconds with 19 queries.
