November 23, 2024, 11:57:13 am *
Author Topic: Video refresh problem and memory error  (Read 7528 times)
cb92110
« on: August 19, 2009, 11:33:25 am »
My config : Dell Latitude D630, 4Gb of RAM, Windows XP SP3
This mail is about xxhighend last release stability.
I used the 0.9x-4 release and it is quite stable on XP except on the memory usage for long pieces of music (classic pieces of more than 15 minutes).
I recently tried to upgrade to the last version and noticed problem on video refreshment. Parts of the GUI appear after put the mouse on the area. It is impossible to use. I decided to restore to 0.9x-4 release. see the screen pictures. The last picture shows an error message with no enough memory !
Any idea about this beheavior ?
CB
XP SP3 => XX 0.9y-503 => AQVOX Universal USB DAC Driver =>Trends UD-10 => SPDIF => Tweaked Micromega Duetto NOS (TDA1541) => SANSUI AU-999 => DIY Loudspeaker AUDAX 21PA15 with double Bass-Reflex. All wires are Cardas except for the loudspeakers : Fadel Art Products.
« Reply #1 on: August 19, 2009, 02:37:41 pm »
Hi CB,
It may sound a bit supid, but a. I have no problem here (Engine#1 and #2 - apart from the large files, but that is always), and b. I have seen exactly the same, including that Resources message.
It is my suggestion that you try the below XXHighEnd.exe. Save your current one (well, what to do with it in your situation Happy) and paste the contents of the Zip over your current XX folder.
With this I'm hoping that I saw this after I put up 0.9y-1d, solved the problem and thus the below version should solve it for you. But I have my doubts ...
Please try it and let me know.
For others, beware : This is not a production version for Engine#3. Don't try it for that !
* XXHighEnd-09-y1dc.zip (513.68 KB - downloaded 468 times.)
cb92110
« Reply #2 on: August 20, 2009, 07:54:58 pm »
Great ! It works better with this new exe except when I click on analysis, I have the following error :
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at XXHighEnd.XXHighEnd.TabDisplayArea_SelectedIndexChanged(Object sender, EventArgs e)
   at System.Windows.Forms.TabControl.OnSelectedIndexChanged(EventArgs e)
   at System.Windows.Forms.TabControl.WmSelChange()
   at System.Windows.Forms.TabControl.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
    CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
XXHighEnd
    Assembly Version: 1.0.3518.24141
    Win32 Version: 1.0.3518.24141
    CodeBase: file:///D:/Hifi/xxhighend/XXHighEnd.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Microsoft.DirectX.DirectSound
    Assembly Version: 1.0.2902.0
    Win32 Version: 5.04.00.2904
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX.DirectSound/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.DirectSound.dll
System.Data
    CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Xml
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
SoundsLike
    Assembly Version: 1.1.2624.38754
    Win32 Version: 1.1.2624.38754
    CodeBase: file:///D:/Hifi/xxhighend/SoundsLike.DLL
LogicNP.FolderView
    Assembly Version: 10.0.0.0
    Win32 Version: 10.0.0.0
    CodeBase: file:///D:/Hifi/xxhighend/LogicNP.FolderView.DLL
System.Management
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Management/2.0.0.0__b03f5f7f11d50a3a/System.Management.dll
Microsoft.DirectX
    CodeBase: file:///C:/WINDOWS/assembly/GAC/Microsoft.DirectX/1.0.2902.0__31bf3856ad364e35/Microsoft.DirectX.dll
System.Configuration
    CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Maybe useful for you ?
Christophe
« Reply #3 on: August 20, 2009, 08:42:49 pm »
Ah good ! As said, I don't know what happened, and probably a bad case of not properly keeping track of things.
That Analysis tab I know. All in there is disabled anyway. I think if you click it a second time you go in there. Not sure, maybe XP behaves differently here. I will look into it.
And thanks for posting that data !
