November 23, 2024, 06:23:19 pm *
Author Topic: 9y-1d and bass response...and 9y-3  (Read 12628 times)
LydMekk
« on: August 19, 2009, 05:59:25 am »
Hi all! Back after a long summer holiday.
Tried the new 9y-1d version today. First impressions:
Very clear and detailed in the treble, very nice resolution overall, good width of the soundstage.
But I think I hear lower level from the midbass down to deep bass than upwards.
The bass is almost played back somewhat cautiously and definitely with lower output than the upper half of the register.
Have updated my settings in my profile.
« Last Edit: September 09, 2009, 07:30:10 pm by LydMekk » Logged
LydMekk
« Reply #1 on: August 19, 2009, 06:06:21 am »
Massive Attack - Angel doesn't make my glasses in the cupboards in the kitchen rattle anymore...  Cool
And it should with 2x13" and a 18" sub...it did before with earlier versions (some time ago).
Are you doing some level-adjustments at some frequencies in the software Peter? If so, please stop and desist... Happy)
« Reply #2 on: August 19, 2009, 07:57:49 am »
Hmm, by now it occurs to me that half of you all is awake at very strange times.  Happy
Ok, besides this irrelevant remark, now an irrelevant question : you have now chosen "DAC Needs 24 bits" (profile) ? and you can use "DAC Needs 32 bits" also ? If so, it seems to me that using 24 is better (more lean) and it sure may change SQ by itself ...
No, because I know I'll get the death penalty for it. You might try the 32 bit setting to get it back ? (if you indeed can switch, and it never occurred to me that DACs (soundcards) could digest both).
But keep in mind (and as always) that at playing Attended SQ is not really under my control, and merely under the influence of the GUI. I'll post a topic about that later (new findings) ...
But I'd like you to judge somewhat longer (yeah, you were doing that all night already swoon) ... What I perceive from that myself (Unattended though) is a far better resolution at the low end. So, less smeared, better followed. The sub woofers are the first to benefit from that, and btw the time I thought they were too slow to follow is long behind anyway. But ... better following means less SPL (hard to explain, but think about better sines and the more a sine is a sine opposed to a square, the less energy it emits -> just math).
So, I sure will not try to talk you into "this is better", but I think it is - but may take some longer listening, and possibly a bit tuning up of the bass section (keep in mind that you may have done so anywhere in the past, the other way around).
I am not sure what music to point you at, but I think I hear it everywhere, mainly in higher frequencies of metal in a bass instrument which seemed to be blown away in earlier versions.
It is difficult too, because it can be very personal, and IMO for sure when one didn't perceive the real merits of bass instruments yet, because it just wasn't possible thus far, it is not uncommon to turn back the bass a Decibel or 6 or more, and be more happy. So, of course I don't need to tell you all this, but bass can be bass sound, and bass can be bass instruments, and bass sound is just not there at all then.
Btw, three days ago or so, for the first time I felt the individual vibes of the low strings of a wing. This is not low at all. But as I said elsewhere (rather long ago) it is my feeling that even a cello should be able to show the individual vibes of her strings. So, the *higher* this works, the better the system works. When this "higher" works, the lower is long behind you because it is so much more easy.
blahblah Cool
« Reply #3 on: August 19, 2009, 10:26:00 am »
I was just thinking : In order to judge for the real merits, your Q2/3/4/5 should be at 0.
Q1 can stay as it is.
LydMekk
« Reply #4 on: September 02, 2009, 11:18:42 am »
http://www.phasure.com/index.php?topic=885.msg7162#msg7162
LydMekk
« Reply #5 on: September 09, 2009, 07:29:35 pm »
Got around to testing Y3 - my bass came back to me...sob...happy tears, mon!  very happy
Thanks, P! Happy
Only blessings from here so far, nice sound.
« Reply #6 on: September 09, 2009, 07:58:29 pm »
... which makes me the most glad. One tiny problem, in this post there's something to download which should solve all : Re: 0.9-y3 Laidback now ?
It helped others ...
LydMekk
« Reply #7 on: September 11, 2009, 01:28:00 am »
Well, y3 is not laidback here...and no problems what so ever. Dunno if I dare change anything atm.
