November 23, 2024, 01:31:52 pm *
Author Topic: No sound from Empirical Audio/Off Ramp 3  (Read 27206 times)
« Reply #15 on: August 19, 2009, 09:28:41 am »
Hi Arvind,
First of all I would say you can't have been using Foobar and WASAPI. In that case the OffRamp will not play when Foobar is set to output 16 bits. Only 24 work.
All will be about Vista works and your understanding of it;
In Vista there are two modes of playing : Shared and Exclusive.
Shared : The sound you play is mixed with possible other sounds and is inherently not bit perfect. Never (or not that I could find). The output to the DAC will be as per the settings in the Properties of the Sound Device - Advanced tab. As you saw, only 24 bit modes can be selected for the OffRamp, 44.1, 48 and 96KHz. Note that the OffRamp can do 88.2 just the same, and it is a Vista bug that doesn't show. BUT, because it doesn't show, it really can't work.
That 16 bit devices don't show is in Steve's hands, or those who wrote the driver software. So, the TAS chip may be able to process it a 100 times, when the driver doesn't allow it, that's the end.
Anyway to keep in mind : what ever you select there, is output to the DAC. This is totally unrelated to what software players output, and if that is 16/44.1 Vista will resample it to what you chose.
Exclusive : The sound you play is left untouched totally. It is therefore bit perfect, when the player denotes so.
As a result, it is up to the player software what can be output to the DAC. Vista doesn't help here. Thus, output 16 bits while the OffRamp doesn't accept that, no dice.
Now, the information from the Advanced tab can be used to determine what the device can do when in Exclusive Mode. It can do that just the same in Shared Mode, but in Shared Mode it will always use what the setting tells. In Exclusive Mode the player software can change when needed, and this is exactly what XXHighEnd does (not Foobar). So, when a 24/192 comes around, it sets the DAC to that, and when next a 16/44.1 is to play, it sets the DAC to that.
You could say all the fuzz can be avoided by using Shared mode, but the problem is that only that one manual setting is used all the time. So, there too different formats can be offered by the player (Engine#1 and Engine#2 just do that), but they are always resampled to the setting in the Advanced tab. Who wants that ? nobody.
All 'n all for you, Exclusive Mode may sound the best, but it is less convenient because at another format you must switch a couple of switches at the DAC.
I think it is clear now ?
And my advise of course is to just use Exclusive Mode and Engine#3, and always comprise a Playlist of the same format.
In XXHighEnd as how it is now, the "format" settings (like Double) are explicit means for technical (SQ) reasons;
In a future version there will be something like "always output like this (format)" which is more how Foobar works. Mind you, using this setting is *not* the best for sound quality, looks like what Vista does for Shared Mode, but avoids switching the switches for those who need to (you).
All 'n all the best is a DAC that is adaptive to automatic sample rate and bit depth changes. Without that you might get crazy from all the existing formats and the (proper) settings it takes at the DAC. Once you are more into hires you will find these the most common :
24/44.1 24/48 24/88.2 24/96 24/176.4 24/192
« Reply #16 on: August 19, 2009, 04:21:31 pm »
I checked the setting of the sound device & it is on exclusive; since the begining. By default it is on this setting.
« Reply #17 on: August 19, 2009, 04:28:17 pm »
Haha, no, it doesn't work like that; What you found  (for those two checkboxes) is only about a. is the device allowed to be used in Exclusive Mode and b. is it allowed to abort other processes using the sound device when Exclusive Mode wants to use it.
It really is player (or the like) software which determines "Exclusive Mode ... NOW !". Only WASAPI (like Engine#3) can do that. Nothing else.
Ask ahead if it is not clear.
« Reply #18 on: August 19, 2009, 04:59:57 pm »
I get it now. Thanks.
« Reply #19 on: August 20, 2009, 05:35:55 pm »
Hi again Peter,
I have trial ordered the Empirical DAC (Overdrive). Now my connections would be Laptop to Off Ramp (via USB) to Empirical DAC (via I2S). The I2S input of the DAC accepts 24/192. How would I ensure that Vista does not interfere with the audio quality?
« Reply #20 on: August 20, 2009, 06:47:03 pm »
Use Engine#3. That's all.
« Reply #21 on: August 22, 2009, 09:12:45 am »
My audio files are 16/44.1 WAV. Setting on XX are DAC is 24/96/Bit Depth is 24/Upsample is ticked/Engine # 3 is used.
Vista is set on 24/96 (though it doesnt matter as I am using Engine #3)
On EMM DAC I switch to 2FS/48KHz.
With these settings XX is upsampling to 24/96 & feeding to the Off Ramp & EMM, which both like. But I am not getting any sound. Why is this?
« Reply #22 on: August 22, 2009, 09:37:51 am »
Hi there Arvind,
No ... with or without these settings (but with the DAC set to 24/96, end DAC Needs to 24 bits) XXHighEnd will output :
- 24/44.1 at "normal" (see below two settings);
- 24/88.2 when Double is ticked.
- 24/176.4 when Quattro is ticked.
So the EMM should be set at 2FS/44.1KHz. Then you should have sound ...
Let me know what happens.
« Reply #23 on: August 22, 2009, 11:40:14 am »
It works with DAC set on 2fs/44.1. Thanks.
Another question what is Q1/2/3/4/5? What should the setting be?
« Reply #24 on: August 22, 2009, 01:34:53 pm »
Q Parameter Settings Happy
