November 23, 2024, 03:36:30 pm *
Pages: 1 2 3 [4]  All
Author Topic: Version 0.9y-1d feedback  (Read 47615 times)
0 Members and 13 Guests are viewing this topic.
LydMekk
« Reply #45 on: August 19, 2009, 05:39:18 am »
Morning,
Running very good, latest version.
1 thing doh,  every album the last track stops at 1 or 2 min before ending. (But could also be last 10 sec)
Roy
Inspiration
This is something known (to some) and I never could find it 6a skips the last piece of the last song in the playlist). And since so many things have been rewritten in this area, I kind of hoped it was away. So it is not. But :
Somehow suddenly a theoretical bug on this sprung to my mind. And, just checked it, and it is true. I never could mimic this myself so I can't check whether the solution helps, but I'm sure LydMekk can make some arrangements with Diana Krall and check. So, should be solved in the next version (0.9-y1a or 0.9y-2).
Hi folks!
Tried it now with the new 9y-1d version, placed 5 different songs from 3 diff. albums in a playlist and played them.
When the last song nears completion it plays audibly normal, but the track counter at the bottom stops about 10% from 100% but the track plays to the normal end as it should.
lol....
The counter also starts going away on each song BEFORE any sound emerges from that song. The counter is probably around 5% into the track when the song itself starts playing audibly.
« Reply #46 on: August 19, 2009, 07:00:01 am »
Yes, this has changed. Not completely intentional but due to technical reasons, and when I saw it I deciced that the old means was as strange.
When time permits I will see if I can make it all the way good (logical).
Thanks for the feedback !
« Reply #47 on: August 19, 2009, 07:01:20 am »
Not yet. Maybe tomorrow...maybe not.
scratching What do you mean ? You didn't try yet or it doesn't work yet ? scratching
PS: The function that may corrupt memory is used more often in the program and I need to work it all through.
« Reply #48 on: August 21, 2009, 02:12:24 am »
This just hits me  wacko
If I play an album and load for eg. the remastered version after that (WITH THE SAME TRACK NAMES)
It can happen that xx will acually do the first album again (how do you know for sure that this can not happen???)
Now you don't !!
 bye
« Reply #49 on: August 21, 2009, 08:40:51 am »
Yes, isnt' that nice ? you wouldn't know the difference eh ? swoonswoon
But I coincidentally solved it a few days ago for loading such an album right after you played the first. I'm actually not sure what happens when you load them both and then start playing the first.
Yes, that happens when you are comparing album versions like I know both you and me are currently doing ... secret
« Reply #50 on: August 21, 2009, 12:36:55 pm »
Sorry I wasn't clear about that Peter. I tried the most recent version and it still doesn't fix the issue of switching between 16/44 and 24/96 tracks in the same playlist. Am currently out of town and won't be able to test again till late Monday.
« Reply #51 on: August 21, 2009, 12:55:08 pm »
Ok, thank you again.
I have just gone through the process of adjusting all the calls to that buggy MS routine (which was at over a 100 places), and I see no memory corruption anymore.
I'll make an official upgrade of that today (0.9y-2), and I can only hope it works for you just the same as it does here for longer already. If not, we must proceed from there and I'll have to make a debug version for it. Sorry for the inconvenience.
Eric
« Reply #52 on: August 24, 2009, 03:42:57 pm »
it has occurred to me that the order in which the albums appear in the library area is different from the standard Windows way. It happens when the album name contains "special" characters. For example, the artist Özay appears at the end of the list in the library area which is different in Windows. Same for the nordic band with the name A-ha. So it looks like you use a sorting algorithm in the library area that is different from Windows.
Not a big deal, but I got confused when I was looking for albums and couldn't find them.
Cheers, Eric.
« Reply #53 on: August 24, 2009, 06:21:40 pm »
Hey Eric, thanks. I am not aware that I do any sorting at all, and it is just "Windows" doing this.
I will look into it though, and maybe I can find some settings for it.
