November 23, 2024, 12:21:42 pm *
Pages: 1 2 [3] 4  All
Author Topic: Version 0.9y-1d feedback  (Read 47569 times)
« Reply #30 on: August 16, 2009, 07:03:47 pm »
XX is playing an album with 5 tracks on it
Can there be 7 unicode files in xx folder?
The thing that happens here is this:
Sometimes in the middle of a track xx starts to play a song from previous album
That is still in there (on C:) I guess.
Can this even happen or am I not hearing this good.
I guess this can happen at least with Attended, and maybe with Unattended too. Both are unintentional, but with Attended things have changed in this area and I guess I did not pay attention to it at all. Anyway, now at last it is clear what you meant by these "other albums". And I suppose you just don't know what you have played an hour ago because you are actually always sleeping. Hahaha. Whimp.
But please tell me whether you encounter this with Attended (thus, other tracks/albums start play at Attended only, no matter these old tracks/albums were from Unattended playback before). The knowledge that this happens with Attended only (that it goes wrong) will save me a lot of searching for the problem.
Thank you, and don't fall asleep. prankster
« Reply #31 on: August 16, 2009, 09:27:11 pm »
Really enjoying this,
Soundstage appears to be much bigger,
The pure bas sounds come out with so much control.
And I am talking about bookshelf speakers (but with homebuild X-over, Phase linear, high-grade parts, better then a 24db per oct tweeters up to 60Khz)
Not that big 300x230x400 or something like that.
But the sound really fills my room (and neighbours(go live somewhere else!))
Massive Attack for eq. has some sneaky basses - xx does music with big basses very well
Never heard a source perform this well.
I know Telstar is going te be a very happy person.
When he finished his build next week combined with this version of XX
« Reply #32 on: August 16, 2009, 10:59:40 pm »
Good good good. wackowackowacko
Any chance answering the question ?
« Reply #33 on: August 16, 2009, 11:16:19 pm »
occurs with Attented playback
« Reply #34 on: August 16, 2009, 11:56:54 pm »
Also, still trouble switching between files of different bit rates in the same playlist. A "Wrong stream status" message now appears. You know if xx could play WMP files I wouldn't have to convert them to 24/96 wave files when they get included in playlists. I've found that converting 192 kbps wmp file to a 24/96 wave file substantially improves the sound of the file. Wishful thinking I'm sure.... Happy
Now you go too fast. First of all I wouldn't know what "a WMP file" is, other than just a WAV file. Second (but the same of course) is : what goes wrong ?
Or did I forget something you talked about earlier ?
About the Wrong Stream Status ... not here. Of course ... swoon. So I guess I now need to know exactly from what to what you try to "switch".
And start praying that it can be solved. scratching
boleary, any news on this ? Let me at least know which format change to which other gives the Wrong Stream Status, so I can try to solve that.
« Reply #35 on: August 17, 2009, 12:38:27 pm »
WMP is really WMA (sorry about that) which is a windows media file.
I get the wrong stream status message when going from a 16/44 file to a 24/96 file and vice versa.
I also continue to get the engine 3 stopped working error when the gui disappears in unattended, if I immediately "alt/p" the file plays. Using task manager, used memory is 1.33 gigs so I don't think its a memory issue.
As others have reported, the sound quality is wonderful!
« Reply #36 on: August 17, 2009, 01:17:16 pm »
I am puzzled about the format switching. Here this is allright, but I already saw this is all very fragile. Hard to explain.
Assuming (and actually knowing) it all worked for you before, a theoratical solution is to let it -per special setting- work the same as before. But this would be a kind of giving in (me), while I'm sure it can go for everyone with the same code. One problem, I can't mimic your sound device, which now seems to play a role.
Also note that many more may be dealing with this, but they won't know because they never try. I never do either for normal playback, so why would I be alone.
I am not sure what to do right now ...
Let me think for a while.
« Reply #37 on: August 17, 2009, 09:39:47 pm »
Wrong :D
I "finished" today. Just the irTrans software to install, then another restore point and add the music HDD and disabling services.
I had an old 500gb seagate disk that i wanted to use for backup but it's fricking hot (45°C) and would raise the internal temps, so it will go out and I'll get another disk. I have to see if the matrix raid can transform a single disk to a raid 1 in a second time (my guess is yes).
I had only one issue with my config and that was the BD drive not being able to boot when in AHCI or RAID mode. Had to put a dvdrom from another computer (still plugged to run memtestx86 all night) to install windows. I put W7 home premium x64 (msdn).
The rig has only one fan, undervolted and runs basically unaudible from 1,5m distance and open case top. So far i'm very happy.
« Reply #38 on: August 18, 2009, 11:35:41 am »
Ok, I found something which was changed, and which indeed may cause it works here and not with you. I undid that change, tweaked something else for it (the change actually was necessary) and now wonder whether it works again for you. Would you care to try ?
In below zip only XXEngine3.exe resides. Paste that over your current XX folder (maybe save the old one first) and give it a try.
(this doesn't solve your other problem, only the format switching (hopefully))
whistle
* XXEngine3-09-1da.zip (65.97 KB - downloaded 471 times.)
« Reply #39 on: August 18, 2009, 01:16:39 pm »
No luck, still get the "Wrong Stream Status (1)" message...... unhappy
There is always the trick that seemed to work for me as a kid: take the broken toy, put it in the closet for two weeks and, viola, its fixed! Just sayin......
« Reply #40 on: August 18, 2009, 01:49:17 pm »
Sure didn't expect that ... unhappy
« Reply #41 on: August 18, 2009, 04:03:28 pm »
Okay, I just found that the "solution" I applied is without effect.
FYI : What I found this morning is that somewhere memory is overwritten, which by itself can't harm (no, this is never good, but within the process it's okay as long as you see what happens with it). In this case, however, it does harm afterall (unlike I thought this morning). So, something has to be "freed", but that can't work anymore, because what is to be freed is unknown since the address of it  is in that part of overwritten memory. Finding the cause will be very time consuming (well, generally it is).
Sorry for now,
PS: This only affects format switching without Stop in between. So no big deal for most I guess.
« Reply #42 on: August 18, 2009, 05:00:57 pm »
Thanks Peter. Will stay with the virtue of patience and continue to be blown away with xx.
« Reply #43 on: August 18, 2009, 07:46:42 pm »
Oh, but this one will work.
Please note I can't test it, because it goes allright in the first place here, but I found the problem of, well, just memory corruption. On that matter, please try whether your other problem is solved as well (the one with solution of Alt-P). Anything could have come from it.
A pure Bill Gates bug btw.
Hope it works now ...
* XXEngine3-09-1db.zip (66.04 KB - downloaded 466 times.)
« Reply #44 on: August 19, 2009, 02:58:04 am »
Not yet. Maybe tomorrow...maybe not.
