November 23, 2024, 12:11:22 pm *
Pages: 1 [2] 3 4  All
Author Topic: Version 0.9y-1d feedback  (Read 47567 times)
« Reply #15 on: August 16, 2009, 08:45:36 am »
before I start my extensive testing of 0.9y-1d , I thought I would quickly highlight an issue playing back files across my network, but didnt have time to report. I noticed it with 0.9ya and 0.9y-1c at least so I expect it may well have been in all 'Y' versions so far.
Engine3 brings up an error message then shortly afterwards the failed message. See below. Logs attached also.
Accessing the same files using 0.9x-7 worked fine.
Hi Russ,
What I see in the log files, can't be explained other than this comes from an earlier 0.9y version (the first or maybe the second). Can that be so ?
If so, it might also be the reason that it fails by itself. It seems straight forward, but I can't let it fail (using your settings and file types).
PS: The next version incorporates the version in the XX log file. Happy
« Reply #16 on: August 16, 2009, 10:40:57 am »
Hi Russ,
I was definately running 0.9y-1d at the time. I have each version in its own folder, and the temporary folder where the logs reside was under my 0.9y-1d entry. It's the first thing I did this morning after downloading it. If you look almost at the bottom of the "XX-20090816-093241" log you will see the path structure I used.
Happy huntin'  grazy
« Reply #17 on: August 16, 2009, 01:45:15 pm »
I've had the dreaded "engine 3 stopped working" error happen frequently with all versions of xx I've used, including 9x-7. Usually it happens about the same time that the gui and task bar disappear. I then "Alt/p and, usually, all is well, but its a little annoying to have to fuss with it to start. I have assumed that it's an issue with the external hard drive not responding quickly enough, a Wester Digital 500 gig. My directory structure, generally, is E/Music/ Artist/ Album. Though I have another folder between music and artist for classical and for jazz. I do not use galleries. Any suggestions?
« Reply #18 on: August 16, 2009, 02:02:55 pm »
How much memory do you have in there ? So, if this kind of not consistent behaviour occurs it is always good to watch TaskManager whether you maybe run out of memory. Note that although it can, this usually is not reported (Out of Memory).
« Reply #19 on: August 16, 2009, 02:11:34 pm »
Hi Russ,
Happy huntin'  grazy
Russ, found it.
Eric, it is my guess that this is your problem just the same.
The length of the ":DATA:" line was read with a too low limit. So, it got truncated and some things can't cope with that. Happy
Btw, it really takes a few coincidences to let this happen, like an unusual deep folder structure (read : lengthy, a share name attributing to that yes), telling that coverart is needed, telling that coverart back is needed.
It is those latter which make the big change opposed to 0.9x-7, and although they were in there already, they were in there faulty because they referred to the original drive (hence no path was needed, because that was known) whereas now the reference to the Gallery it resides is explicit.
And so the line could get too long ...
Solved for the next version.
Eric, to be sure whether this is your problem too, please post the X3 log file from an occasion it happens.
« Reply #20 on: August 16, 2009, 02:28:48 pm »
4 gigs of memory, don't think it's a memory problem. There is, of course, the likelihood that this is also connected in some way to "user error of the marginally computer competent" Wink
« Reply #21 on: August 16, 2009, 02:35:32 pm »
I think you will be ok with that one. very happy
But I still like to know the useage at the time it goes wrong (must start somewhere). And to keep in mind : one process can't use more than 2GB anyway. So, if you see something around that area we must look into the why. If it is significantly lower (like 1.4GB or so) we must look somewhere else.
« Reply #22 on: August 16, 2009, 02:40:41 pm »
Also, still trouble switching between files of different bit rates in the same playlist. A "Wrong stream status" message now appears. You know if xx could play WMP files I wouldn't have to convert them to 24/96 wave files when they get included in playlists. I've found that converting 192 kbps wmp file to a 24/96 wave file substantially improves the sound of the file. Wishful thinking I'm sure.... Happy
« Reply #23 on: August 16, 2009, 02:50:17 pm »
Now you go too fast. First of all I wouldn't know what "a WMP file" is, other than just a WAV file. Second (but the same of course) is : what goes wrong ?
Or did I forget something you talked about earlier ?
About the Wrong Stream Status ... not here. Of course ... swoon. So I guess I now need to know exactly from what to what you try to "switch".
And start praying that it can be solved. scratching
« Reply #24 on: August 16, 2009, 03:25:32 pm »
Russ, found it.
Warning :
I am not sure how the status can get, but after I finally got it running (but maybe earlier, and it is about that !!) the file Played.dat in the XX folder contains the references to the shared drive. Allright. I've been just looking for over an hour why suddenly XX wouldn't start anymore after I earlier noticed that startup went *very* slow (think over 30 seconds). I just found the culprit ...
There's an official command that brings back the Dos 8.3 Short Name to the normal Long Name. This just doesn't work for a Share. Maybe it can work occasionally, but then very slow (see above), but it also can end up just doing nothing (or maybe stall the PC the Share is from, I don't know).
(btw, I have the feeling I already knew this, but anyway not for this part of the code).
So, when it happens to you that suddenly you can't get XX started anymore after playing (or attempts to do so) from a Share, delete the Played.dat file from your XX folder. Then it is okay again.
Of course this will be solved in the next version, although right now I don't know yet what the consequences will be.
« Reply #25 on: August 16, 2009, 04:14:46 pm »
Hi Eric,
1. Pressing Clear and Off does not permanently delete the playlist. The list will be back when XXHE is restarted.
Well, I didn't say that this was solved, or ? Happy swoon
Next time. Some things were more important I think ? (of course if they weren't important there was no need to upgrade already !). Anyway, I',m sorry ...
It's in for the next version.
Eric
« Reply #26 on: August 16, 2009, 04:53:18 pm »
Thanks Peter,
I will be happy to test when the next version will be released.
BTW: what's your plan for it ?
Cheers, Eric.
« Reply #27 on: August 16, 2009, 05:39:32 pm »
XX is playing an album with 5 tracks on it
Can there be 7 unicode files in xx folder?
The thing that happens here is this:
Sometimes in the middle of a track xx starts to play a song from previous album
That is still in there (on C:) I guess.
Can this even happen or am I not hearing this good.
« Reply #28 on: August 16, 2009, 06:02:14 pm »
I see how it works now,
there are always 7 unicode files in the xx folder,
and they are being written over. (so there can be tracks from like 3 albums in there)
So the thing that happens to me can really occur.
Right!
« Reply #29 on: August 16, 2009, 06:47:04 pm »
Then you start to wonder,
Did you made use of a (sortlike) partition on C:
Pre-Reserved space or something.
(or clustergroups or adresses that are following up)
or maybe on the RAM.
Is this the foundation for the better SQ ??
