November 23, 2024, 11:59:38 am *
Pages: [1] 2 3 4  All
Author Topic: Version 0.9y-1d feedback  (Read 47565 times)
Eric
« on: August 15, 2009, 06:41:06 pm »
Hello Peter.
My comments on version 0.9y-1d.
Unfortunately the 2 problems I reported before still exist.
1. Pressing Clear and Off does not permanently delete the playlist. The list will be back when XXHE is restarted.
2. Occasionally XXHE does not start. Happens with some tracks on C-disk. Error is persistent, can be recreated. Error occurs with both parameter ticked or unticked.
Other point: the AutoHotkey message keeps pointing to 0.9y-1c. How to change that?
In the mean time I will spend some time listening.
Cheers, Eric.
« Reply #1 on: August 15, 2009, 07:20:29 pm »
Hi Eric,
Well, I didn't say that this was solved, or ? Happy swoon
Next time. Some things were more important I think ? (of course if they weren't important there was no need to upgrade already !). Anyway, I',m sorry ...
Well, I asked you that question about this, and I didn't see an answer. I tried ... yes. So ... next time also. But no problem, it will be solved.
Please try to make clear what type of file you are playing, from exactly where (folder) and what the name is. Additionally, what file type (etc. etc.) does play ? please give a similar example and use the same settings when you try.
AutoHotkey : Start XXHighEnd, then start AutoHotkey again. Then it should be okay, and you will receive a message which may help you. Otherwise its is all in here : AutoHotkey Install.
Let me know if you can't get it done.
Eric
« Reply #2 on: August 15, 2009, 07:42:42 pm »
Peter thx
1. N.P., just a reminder
2. Will do, tomorrow
AHK problem disappeared after reboot.
Cheers, Eric.
« Reply #3 on: August 15, 2009, 11:55:22 pm »
short note,
still no luck with that Dreamtheater folder,
and come across more and more folders that refuse to play.
And get this error-message, when play is pressed.
logs attached
* X3-20090816-025936.log (1.34 KB - downloaded 533 times.)
* XX-20090816-025917.log (24.5 KB - downloaded 508 times.)
« Reply #4 on: August 16, 2009, 02:13:11 am »
before I start my extensive testing of 0.9y-1d , I thought I would quickly highlight an issue playing back files across my network, but didnt have time to report. I noticed it with 0.9ya and 0.9y-1c at least so I expect it may well have been in all 'Y' versions so far.
Engine3 brings up an error message then shortly afterwards the failed message. See below. Logs attached also.
Accessing the same files using 0.9x-7 worked fine.
* X3-20090816-093255.log (1.34 KB - downloaded 548 times.)
* XX-20090816-093241.log (14.38 KB - downloaded 516 times.)
« Reply #5 on: August 16, 2009, 03:38:34 am »
Just found a crazy little glitch grazy
Folders named B.B. (like in B.B. King or B.B.E)
just klik such folder in your gallery
xx doesn't like those names.
« Reply #6 on: August 16, 2009, 03:58:15 am »
And renaming a file in xx, destoys the file.
Don't hit right click on a pic, then rename function
So watch out !!!!!!!!!
Roy
« Reply #7 on: August 16, 2009, 05:02:34 am »
Roy
Hi Audiodidakt
Are you talking about just renaming a *.jpg and it "destroys" the pic? or all the files in the folder... like the wav and cue files??? Not going to try this myself yet hehe.  but curious.  As a side,,, I've always been a bit leery of having xxhe do deleting a file... don't want to make a mistake.... if I'm deleting/renaming wav/cue files I pull up explorer... but I've used the rename for pics, ie. back.jpg/folder.jpg.
I've listened to about 8 albums today (both 44.1 & 96) and not run into any glitches... but I treat things with kid gloves and reboot too much I'm sure, heh.  Just about to sit down to more listening... I think xxhe took a small step forward in SQ (purer/weightier highs... also turned down bass a smidgeon... so maybe a difference in 'balance'), but I may think that's a bigger step as I settle into the night listening,,, mostly today it's been background.
...I only have two folder depths to get to my music ie.  Rock folder > artist1 - album1 folder > wav/cue.... Rock folder > artist1 - album2 folder > wav/cue ... and so on.... kid gloves.  The deeper you go in adding folders the slower I think things go... could that be why xxengine3 not starting on time for some?  I'll see if I can find a B.B. type album... but I avoid putting '.' in folder/file names.
« Reply #8 on: August 16, 2009, 05:20:51 am »
No, just that one pic.
Don't like to try either.
Normally I do things outside XX
Should make a dummy (copied) folder and try.
Speed and response time are REALLY GREAT with this new version.
faster starup, faster playback. (more responsive)
Add that up with resizing your folder.jpg to normal size.
And you find that this version of XX to be really fast.
About SQ, it sounds more sofisticated in the higher-ends. (but it takes good eares to divine the differences between those versions)
This version is sure TO STAY, just workout those glitches.
« Reply #9 on: August 16, 2009, 05:45:21 am »
And I already had an SQ update,
With that new GA-EP45-EXTREME motherboard,
overclockers board with better voltage and power regulation.
or maybe better power-plans on board, I dunno.
But it really does the job very well.
Now if only had a good DAC, Hmmm, Hahaha Wink
« Reply #10 on: August 16, 2009, 07:05:36 am »
After more listening,
Start to get more amazed by the SQ, can't stop listening, help.
Surpriced how well it sounds.
What have you done?
Soundfield is much wider to the sides, and more into the room.
Just listen to trompets for eq.
Really worth waiting for a few months.
Must be a whole lotta work.
This version takes it to the next level (going in to that 1.0 version)
I do understand why everything is rewritten,
everything is implied better and faster  too much !
THNX
« Reply #11 on: August 16, 2009, 07:36:35 am »
Hey Roy, how does it sound now the sun is up ?  Cool
« Reply #12 on: August 16, 2009, 07:44:52 am »
Quail
« Reply #13 on: August 16, 2009, 07:51:35 am »
LOL
« Reply #14 on: August 16, 2009, 07:57:18 am »
Peter thx
Cheers, Eric.
Eric, as how I see it now, it may be sufficient to attach the log files (XX and X3) from a situation concerned. If I then need more I'll let you know.
