November 23, 2024, 12:23:37 pm *
Pages: 1 2 3 4 5 6 [7]  All
Author Topic: Re: Version 0.9y-1 feedback  (Read 86353 times)
« Reply #90 on: August 15, 2009, 04:24:35 pm »
Hmm ... you are right. Just before upgrading. Happy
Always you eh ?
haha
Thanks !
« Reply #91 on: August 15, 2009, 04:31:52 pm »
Hoped I could slip that in before upgrading! Thanks.
« Reply #92 on: August 15, 2009, 05:33:41 pm »
Both issues are solved (info tab and format change). Upgrade coming up now.
heat
« Reply #93 on: August 15, 2009, 05:53:01 pm »
Dear all,
I want to thank you for spending all this time on getting done in 48 hours which I myself could not achieve in even ten times more;
As the earlier 0.9y Release Notes already stated, "not stable". Not because I knew the issues, but because I sure knew not enough time was spent by me on testing just everything. I know this is not the official way, but it seems the only way workable. At least at these major changes it is (which never have been so major and numerous before, and of which I sure hope it will never happen again).
Of course, at this time, it still is so that too few people tried the 0.9y version (from here on, 0.9y-1d or newer please), so it is my guess there is more to expect. Anyway, 0.9y-1d should be much better, and at least I have a much better feeling about it now.
Russ, although I have been spending quite some hours on your problem this morning, I could not find anything that really causes your "no sound at some times". However, I have changed rather essential code in an area of which I may expect it matters.
If you still encounter this problem, please open a dedicated topic for it so it can be treated in there without the confusion of more general things which normally are solveable at a glance, so to say.
All the best to everyone, and again, thanks.
« Reply #94 on: August 16, 2009, 04:32:54 am »
Morning,
About that "resize to 500 x 500" good
On my new little screen (18,5"), I'll have 1360x768 (took a model with low resolution native on purpose).
If we make it 600px, it would be perfect Happy
I agree with Roy that some biiig pictures in the gallery make it slow. I have really huge scans saved as folder.jpg.
I did some testing with those folder.jpg files
Just resize everything above 900x900
IMO resize 700x700 would still be a good picture and also fast
Because most covers are already smaller than 600x600
So if we could resize those eq. 2800x2800 to 700x700 would be great. (and delete the original)
« Reply #95 on: August 16, 2009, 05:07:36 am »
I'm not convinced it's size 1024X1024 or whatever... it's the size of the file ... I ran into some .jpg that were like 8MB or something (how does a pic get into the 8 - 12MB size? something embedded?)... after I resized them myself to 1024X* they were in the kb range and sped up... also, folder depth ... like having one folder for an artist and putting all their albums in folders underneath that ... bleh slowed things down... that's with x7 ...dunno about this latest Y version.
« Reply #96 on: August 16, 2009, 05:53:53 am »
Explain "bleh slowed things down"
What do you mean by this?
What is getting slower
« Reply #97 on: August 16, 2009, 08:08:51 am »
probably just x7 and before... library would slow down/load pictures slow as you scroll down when I hit folders that were buried.
I'm not bragging here, but I do seem to have less problems with xxhe, (?dedicated machine/services off, file structure, wav/cue files, 'careful' setup of each version of xxhe...?) I haven't had a single disc not play all the way through today... or is that just because I waited to load Y version until today,,, after you all did all the 'beta' testing hehe ... btw THANKS everyone!!!
hmm why do I have this craving for some blue oyster cult...
« Reply #98 on: August 19, 2009, 11:57:09 am »
Scan at high dpi without compression. But to be 8MB it has to be 2000x2000 or above.
You guys really need to use photoshop to do this job. I download lots of covers from allcdcover and half of their scans needs to be cropped, smoothed and colors adjusted. Then I usually leave the normal resolution. I think I should instead make a smaller version 600x600 or 700x700. My own scans are set at 72dpi (screen resolution) and around 1000px IIRC.
Now that I have most of the DB already built it would be quite a pain to go trough all that and resize all. But indeed having lots of big covers makes the library quite slow.
Edit: didnt try the latest versions yet.
« Reply #99 on: August 19, 2009, 02:50:26 pm »
and
Well, I hope for you this is a typo, and it should read 92. If you have a display with 72dpi it may be worth some money (for the museum).
oops
Anyway, I keep them to the normal physical size, and for 92dpi that would be 500x500.
Further, notice that the number of albums hence pictures you hve in there, really doesn't matter for Gallery speed. It is the size of the pictures what does, and besides that, though slightly relevant only, the means the pictures are stored. Think of a Folder.jpg to be found immediately for the coverart (although I think Cover.jpg is earlier to find), if not some intelligence has to be applied (although most of it is out in the 0.9y versions and it now is far more easy to see a back cover because of not complying to the naming conventions -> earlier this was all sorted out better), and whether you have a separate "SCANS" etc. folder where all is to be found, when no Folder.jpg is in the main music folder.
Multi volume albums require some additional attention especially when you have a separate folder for coverart again. Oh, note that only in the upcoming version this now works ok (at last, it never did).
Lastly, notice that there is no single reason to make the front cover large. The maximum size of the screen really is large enough, and if it is smaller (like 500 x 500) you really wouldn't see the difference because the rendering applied. And it is those who slow down the Gallery, not all the other sh*t. Make that 6000x6000 if you want, it really doesn't harm, as long as XX doesn't think it is the front cover. Also, for the other stuff it indeed is (or could be) important to be large, because that often is about text to read, which otherwise (like at 500x500) can not be read at all.
HTH
Eric
« Reply #100 on: August 26, 2009, 02:16:13 pm »
Re 0.9y-1c.
Occasionally when I load a track and press Play, I get the error message  "XXEngine3.exe werkt niet meer" and the show stops. In trying to find out when this happens, it occurs to me that when it happens, I play from the C-disk. So far, it didn't happen when I play from another disk. However, not all tracks from the C-disk give this problem.
I never saw this happening in 0.9x-7.
I hope this helps you with debugging.
Eric.
just to inform you that up to now, the poblem quoted above hasn't shown up in 0.9y-2. Moreover, the test that I created in my environment to generate it, now runs okay.
Thanks, Eric.
« Reply #101 on: August 26, 2009, 02:20:35 pm »
Ah Eric, that is very good to hear, and much appreciated that you gave feedback on this.
The problem was more general, and as you saw in the Release Notes on 0.9y-2 several of these things have been found and solved (although I described it merely as "no sound").
Anyway, good to hear that one has gone too !
Page created in 0.125 seconds with 19 queries.
