November 23, 2024, 12:25:45 pm *
Pages: 1 2 3 4 5 [6] 7  All
Author Topic: Re: Version 0.9y-1 feedback  (Read 86356 times)
« Reply #75 on: August 15, 2009, 01:13:26 pm »
Additionally (I'm off here now), when you find it ... whatever it is ... what values can it have, what do they mean, and what should it be reset to ?
Or anything else you (I) may need to add ... (this is going to be dangerous haha, so don't overdo things if you don't trust it).
Oh, I see you are just ahead of me. TileWallpaper ... but I use that already. Hmm ...
Nothing going on with that wallpaper,
Telstar just save your personalize settings.
Think that solves it, In my case it did.
GRtz Roy
« Reply #76 on: August 15, 2009, 01:25:15 pm »
Hi Peter. I really like the speed of 9y-1c. Everything here seems to run much faster and smoother. I also really like the way you can see tracks being processed in unattended, though both the first and last track don't get highlighted. The release notes only refer to the first track not being highlighted. Regarding other glitches the hotkey command for explorer, ALT R, doesn't work. Also when I pause in unattended, ALT E, and then resume play, ALT P, the track starts from the beginning. I think this was true of   9x-7 too.
Regarding sound quality, I'm going to post in the other thread, but all seems very well!
Thank you.
Last track not highlighted ... not sure, but I think that is because at that time the GUI is just closing. So, it closes earlier than you can see the last track getting highlighted. Think like this : last track is finshed prepapring thus ... a. higlight it, b. quit asap. The asap has prevalence ... (I guess). I could wait for the track being highlighted, but that is stupid I think.
I will try to get the first track solved.
Alt-R just works here, and this may be about the Alt keys (for Attended !!) not working always ? That is what I see myself anyway. I don't know what it is, but it is outside me. Note that Alt-R is unrelated to AutoHotkey (and it is for Attended only).
The Pause etc. I am currently working on as a last thing before a new upgrade (and your Track 1 maybe). I am not sure I will solve it before that, because it is a tedious bugger - and has always bugged me. Btw, it should work extra "bad" in the 0.9y version(s). Before it worked better.
Thank you very much for your feedback !
« Reply #77 on: August 15, 2009, 01:25:58 pm »
Yep, like the speed too.
Its sure faster, overall performance is really great.
« Reply #78 on: August 15, 2009, 01:28:18 pm »
GRtz Roy
Aha. Roy, you may open a new topic especially for this. Describe what to do and such. I guess once W7 gets more common more people will be bothered by this.
If you don't want ... allright of course.
« Reply #79 on: August 15, 2009, 02:03:30 pm »
Morning,
About that "resize to 500 x 500" good
On my new little screen (18,5"), I'll have 1360x768 (took a model with low resolution native on purpose).
If we make it 600px, it would be perfect Happy
I agree with Roy that some biiig pictures in the gallery make it slow. I have really huge scans saved as folder.jpg.
« Reply #80 on: August 15, 2009, 02:04:04 pm »
Thanks for the feedback Telstar.
On 2), is that when XXEngine3.exe is not running ? ... that works ok here (in that case). And if so (XXEngine3 not running), how do you close XXHighEnd ?
From the X button in the top corner of the window (remember that i always play attended).
« Reply #81 on: August 15, 2009, 02:11:39 pm »
Telstar - Just tried everything here (Attended) but can't let it go wrong.
Is there any situation that this goes right with you ?
Or otherwise you may show all your settings ? (I'm almost up to the upgrade so I'd rather take the solution along with it).
« Reply #82 on: August 15, 2009, 02:21:39 pm »
Sorry,
Is this still about that wallpaper,
That is W7 sh#t, not XX.
Telstar, Rightclick desktop, Personalize, Desktop background, choose Picture position.
Then save changes.
Fixed!
Had this many times before (when started playing Unattended and forgot to activate AHK)(And I sure I am not the only one!!)
Your left with two choices, reboot or wait for xx to finish.
after reboot wallpaper settings are also changed.
Eric
« Reply #83 on: August 15, 2009, 02:50:17 pm »
Re 0.9y-1c.
Occasionally when I load a track and press Play, I get the error message  "XXEngine3.exe werkt niet meer" and the show stops. In trying to find out when this happens, it occurs to me that when it happens, I play from the C-disk. So far, it didn't happen when I play from another disk. However, not all tracks from the C-disk give this problem.
I never saw this happening in 0.9x-7.
I hope this helps you with debugging.
Eric.
« Reply #84 on: August 15, 2009, 02:55:04 pm »
Eric - This is about the poor implementation of that CopyToXXDrive thing in the first place. That is, I suppose you are using that parameter when playing from the C disk, as you say.
If all is right this is solved in the upcoming version (0.9y-1d), although I didn't particularly see what you described. But it was wrong anyway.
Edit :
PS: But I actually wonder (at reading your post again) whether you are talking about that parameter. Are you ?
« Reply #85 on: August 15, 2009, 03:00:02 pm »
XX plays tracks out of the blue,
When playing an album it suddenly likes to play another song.
Not a track on the current album, but a song on a completly different album
Best is to wait for new version and see what happens.
« Reply #86 on: August 15, 2009, 03:05:49 pm »
Special randomizer. Happy
« Reply #87 on: August 15, 2009, 03:10:15 pm »
Then save changes.
Fixed!
I always use fill, never tile (which in vista was crop or something) and i'm using the landscape theme atm.
Anyway, I'll try more on the dedicated pc, i dont use wallpaper here.
« Reply #88 on: August 15, 2009, 03:13:33 pm »
Then save changes.
Fixed!
Its either the "Fit" or "Fill" setting.
Use Fit
« Reply #89 on: August 15, 2009, 03:35:17 pm »
Looks like the previous problem of xx  not being able to switch from a 14/44 to a 24/96 song, or vice versa, in the same playlist is back. Additionally, the info tab which gives the bitrate isn't functional. No hurry here, love the improvements.
