November 23, 2024, 12:28:47 pm *
Pages: 1 2 3 4 [5] 6 7  All
Author Topic: Re: Version 0.9y-1 feedback  (Read 86358 times)
« Reply #60 on: August 14, 2009, 04:22:56 pm »
Why not clear the playlist after finishing an album. (just clearing finished albums)
Can you tell me the purpose of having those songs staying in the playlist when finished an album. (its not like I'm playing it twice or something like that))
Am I overlooking something here?
Is there a possible way to maybe build-in an "Auto-Clear" function checkbox □.
(as in upon deleting unicode files also delete the ones in playlist)
Also with maybe future plans of remote control (selecting a direct song) (otherwise with more than 1 played album in playlist for eq. location of track 8 is never certain)
If playlist clears the album after playback, (with for eq. the button next album) location of for eq track 8 is certain
I dunno, just a thought!
Roy
« Reply #61 on: August 14, 2009, 06:00:14 pm »
Roy - Although it only looks complicated this way, it has its reasons. So, you shouldn't be bothered about this (what about not looking at it).
About the tracks being kept in the playlist ... I wouldn't them to get removed as soon as they have played. Maybe I want to see afterwards what I even played (which is not always known, depending on the means of playback). So, this for sure will stay too.
Again, that this may make things more complicated for sure is true, but it all has good reasons.
Thanks though !
« Reply #62 on: August 14, 2009, 10:29:36 pm »
This is for Russ and everybody else who wants to know of course :
Despite what some may think, this really isn' working. At least with separate FLACs (Unattendedly) there is no way to pause and continue, or change the volume and the like, or tracks end too soon, start too late and everything else which is not intended.
So, especially for Russ, please don't bother at this moment to invest all this effort in finding out what is going on. It needs the reverting of the changes I applied day before yesterday - possibly implement that in a better way (the Copy to XX-Drive thing) or whatever, but this is not it.
Sorry.
PS: I hope to upload something better in something like 12-13 hours from now.
« Reply #63 on: August 14, 2009, 11:51:10 pm »
Short playtime and two bugs (tested on W7 RTM x64):
1) start button disappears
2) background does not returns to normal when i close xxhe (this was solved for me in a previous build)
luv the long tree Happy
« Reply #64 on: August 15, 2009, 12:05:22 am »
Thanks for the feedback Telstar.
On 2), is that when XXEngine3.exe is not running ? ... that works ok here (in that case). And if so (XXEngine3 not running), how do you close XXHighEnd ?
« Reply #65 on: August 15, 2009, 12:15:21 am »
about that back ground pic.
I have a HD background pic and xx gives that pic back after playback
but the wrong settings.
there is extra layer in W7 (extra settings)
zie pic.
Think Telstar means this, I guess
« Reply #66 on: August 15, 2009, 12:16:00 am »
yahoo Found this one; Only minutes before the first 0.9y upload I changed something of which I couldn't see the danger. foolfool
However, that caused a start of playback not at the beginning (being the same as e.g. changing the volume underway) to repeat as a start offset into every track.
Roy, although I found/solved a problem I was seeking for a long time (under "Inspiration" in the earlier post), this has really been the problem you had, I'm sure.
So, for the current 0.9y-1c, as long as you don't do the things I just mentioned, you will be okay I think. This does not count for the problem of no sound at all sometimes (as per Russ's extensive outlay). Or at least I don't see the relation to that.
The Copy to XX-Drive changes have been reverted by now. More tomorrow.
« Reply #67 on: August 15, 2009, 12:22:09 am »
zie pic.
Hey Roy. Thanks for that ! However, I can't get what that extra setting is. Can you help me ?
currently I use (may it say something to you) WallpaperStyle and TileWallPaper (and of course Wallpaper itself). These three are subkeys in "CurrentUser","Control Panel","DeskTop" in the Registry. I guess you talk about another (new) one. But which is it ?
« Reply #68 on: August 15, 2009, 12:28:25 am »
look for yourself
« Reply #69 on: August 15, 2009, 12:30:26 am »
Additionally (I'm off here now), when you find it ... whatever it is ... what values can it have, what do they mean, and what should it be reset to ?
Or anything else you (I) may need to add ... (this is going to be dangerous haha, so don't overdo things if you don't trust it).
Oh, I see you are just ahead of me. TileWallpaper ... but I use that already. Hmm ...
« Reply #70 on: August 15, 2009, 12:32:33 am »
Maybe you can make a screenshot of how things must be (when all is OK according to you) and one of how XX leaves it when it's wrong ?
sleeping
« Reply #71 on: August 15, 2009, 12:33:38 am »
Sorry dont know for sure,
I only saw the problem.
look into that tomorrow
Grtzzzzzzz
« Reply #72 on: August 15, 2009, 12:35:11 am »
Don't feel obliged to do this.
« Reply #73 on: August 15, 2009, 09:42:02 am »
Morning,
About that "resize to 500 x 500" good
Make your life easier and resize!
Its takes time to do all, but your being rewarded by a superfast gallery (scrolling like crazy grazy)
This is just great, not even have my gallery on SSD, yet.
Thanks for that Peter
I think this is solved too!!!!!
« Reply #74 on: August 15, 2009, 12:41:53 pm »
Hi Peter. I really like the speed of 9y-1c. Everything here seems to run much faster and smoother. I also really like the way you can see tracks being processed in unattended, though both the first and last track don't get highlighted. The release notes only refer to the first track not being highlighted. Regarding other glitches the hotkey command for explorer, ALT R, doesn't work. Also when I pause in unattended, ALT E, and then resume play, ALT P, the track starts from the beginning. I think this was true of   9x-7 too.
Regarding sound quality, I'm going to post in the other thread, but all seems very well!
