November 23, 2024, 12:11:54 pm *
Pages: 1 2 [3] 4 5 6 7  All
Author Topic: Re: Version 0.9y-1 feedback  (Read 86350 times)
« Reply #30 on: August 13, 2009, 06:19:52 pm »
Can you attach the XXDat0000.dao, XXDat0000.dat, XXDat0001.dao, XXDat0001.dat files ?
They don't need to exist all, so please post what you find (in your current XX folder, and note they are hidden). Please watch the date/time of them. They must be actual. If they are not there anymore, start XX, press play - wait until you think it is ready, now also post the log file again, and those dat files.
Please, of course. Happy
« Reply #31 on: August 13, 2009, 06:28:10 pm »
and,
* XXDat0001.dat (0.37 KB - downloaded 498 times.)
* XX-20090813-182200.log (22.69 KB - downloaded 515 times.)
« Reply #32 on: August 13, 2009, 06:55:12 pm »
Ok. Another 30 log lines (none of the before showed up swoon). But this time we will see what happens. And I already have an idea ...
Just paste this over the latest .exe. Don't forget to set the loggin on.
* XXHighEnd-09-y1b.zip (513.37 KB - downloaded 490 times.)
« Reply #33 on: August 13, 2009, 06:59:53 pm »
still no playback
* XX-20090813-185349.log (22.9 KB - downloaded 498 times.)
* XXDat0001.dat (0.37 KB - downloaded 502 times.)
« Reply #34 on: August 13, 2009, 07:03:00 pm »
Now a question. Did you press Stop or anything ? If so, once again please, but don't touch anything.
If not, I can proceed with this.
« Reply #35 on: August 13, 2009, 07:06:34 pm »
If I don't stop I can not send you a .dat file only log files.
In use by xx
« Reply #36 on: August 13, 2009, 07:09:02 pm »
Aha, but I need the log file. The dat is not important anymore. Sorry for the misunderstanding. So, without Stop please.
« Reply #37 on: August 13, 2009, 07:11:48 pm »
ok
* XX-20090813-185349.log (27.46 KB - downloaded 479 times.)
« Reply #38 on: August 13, 2009, 07:20:15 pm »
Hahaha, stupid prick. Why didn't you ever select an Input Device, huh ?
And don't tell me "because it is disabled". You know your ways ...
fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool fool
So ... this is about the analysis part, and I forgot to deactivate this particualr bit. No Input Device selected (for recording), and you're out. And you probably don't have one that can record, so there's no default either.
Right, that was one problem.
Anyway, very sorry !
Now, I'll try to make yesterday's changes more decent/stable. heat
« Reply #39 on: August 13, 2009, 07:46:22 pm »
Oke found it,
We have sound. very happy
But have to play with dac settings
And yes it was switched off, sorry for that
« Reply #40 on: August 13, 2009, 08:01:59 pm »
THNX Peter,
Up and running but it aint perfect, but we know that.
Track 1 stops after 1 min
try to play some music and report any glitches
Thnx for now
« Reply #41 on: August 13, 2009, 08:59:55 pm »
I just put up an 0.9y-1c. Nothing else solved but that supid mistake on the Input Device, and the additional logging is still in there.
In the mean time I'll try to make something better out of it all.
Roy, thank you for your time.
Eric
« Reply #42 on: August 14, 2009, 12:28:17 am »
just some words as encouragement.
This version seems to be quite stable in my setup. I am in the proces of comparing SQ with 0.9x-7. My first impressions of 0.9y-1c SQ are good. I will come back to the subject later.
Cheers, Eric.
« Reply #43 on: August 14, 2009, 12:30:35 am »
Thank you Eric. I will sleep on that (for now Happy).
« Reply #44 on: August 14, 2009, 04:04:20 am »
My impressions also Happy
I'm currently compiling some notes on a series of listening sessions with accompanying log files. Hopefully will have them ready for you Peter while you imbibe your morning caffeine intake.
