November 23, 2024, 11:44:43 am *
Pages: [1] 2 3 4 5 6 7  All
Author Topic: Re: Version 0.9y-1 feedback  (Read 86346 times)
« on: August 13, 2009, 12:17:14 am »
Some tooltips of the new parameters are missing.
« Reply #1 on: August 13, 2009, 12:30:11 am »
Yeah, I think I knew that. sorry
« Reply #2 on: August 13, 2009, 12:37:06 am »
Hey Peter,
Thnx for this new version, at first glance looking really good.
XX remembers my settings and larger gallery looks nice.
But xx wont play. (even with "copy to xx drive by standard" disabled)
Roy
« Reply #3 on: August 13, 2009, 12:40:02 am »
Looks good, but won't play. Hmm ... swoon haha
Can you be more specific please ?
« Reply #4 on: August 13, 2009, 12:44:50 am »
see settings above,
And ofcourse using W7.
selected an album from gallery and tracks are shown in playlist
Then press play and nothing happens.
« Reply #5 on: August 13, 2009, 12:50:19 am »
What kind of files do you try to play ?
Maybe attach your XX and X3 log files ?
sleeping
« Reply #6 on: August 13, 2009, 12:55:50 am »
seperate FLAC files no cue,
Unicode file is in xx folder.
But simply doesnt start
Even when I converted my files to wav and "copy to xx drive by standard" disabled
* XX-20090813-004825.log (0.51 KB - downloaded 518 times.)
* XX-20090813-004847.log (17.88 KB - downloaded 509 times.)
* XX-20090813-005103.log (17.29 KB - downloaded 566 times.)
« Reply #7 on: August 13, 2009, 02:07:36 am »
Alt X command gives following error (same in 09y): see attachment
« Reply #8 on: August 13, 2009, 09:02:07 am »
Good morning Peter ...
better make that first cup of coffee extra strong today .. hehe
0.9y-1 is proving rather problematic during unattended play. Most times it will stop at the end of a song (which appears for the majority of the time to be after the first track) and then refuses to come back to life. I've even had it refuse to start playing when the GUI disappears. In those instances sometimes the folder art is displayed and othertimes it isn't.
Attended playback, from the limited time I've used that function, appears to work as planned.
The sound quality is still as exciting as ever, and since I haven't been spending much time in recent weeks actually listening to music, just reinforced how good it is Happy
Hopefully this glitches are the result of timing issues.
I can swamp you with logs if you need them, but figured you have a plain test machine set up you use to trouble shoot new versions. But you're likely aware of these issues anyway. This post was just to let you know I'm here with some spare time to help nutting out these problems.
« Reply #9 on: August 13, 2009, 09:06:11 am »
Forgot to set the Autohotkey shortcut property to administrator. This solves that "No right..." error with Alt X.
« Reply #10 on: August 13, 2009, 09:12:05 am »
Roy,
I can't get this. But looking at everything I'd say it will help if you untick "Start Engine3 during conversion".
Please let me know. Here is sure works (just mimiced your situation as good as possible).
One thing : The file you try to play here has a space before the dot like 01 - Pistolero .flac
Officially this can't be. I looked in the program combined with the log files, but don't see where it would matter, unless the OS itself chokes on it. You might try without such a space ?
« Reply #11 on: August 13, 2009, 09:43:33 am »
Very much appreciated Russ. But maybe those log files are needed indeed. That is ...
I already now (after the issue Roy seems to have) have the feeling something fishy is going on. So, no, I never experience that playback stops after one / the first track, BUT, I encountered something like "no sound at all" myself yesterday, and for the life of me couldn't think of why, and the "solution" was to revert a change I just made before. Russ, if you can copy this behaviour, it would be the most helpful if you could try 0.9y again. If you switch On the OSD Running Time it just works (that must be how Johan got the old version working). Don't show Coverart will let it work too I guess (might be needed for Attended).
Below there's the old version again, this time including those two dll's.
Side info (maybe for all) : I have really been working for a month (that's 7 days a week 10 hours per day or so) to get this all in an acceptable fashion, the last two weeks every day thinking I got it, while it went wrong at the first "official playing of music" in the evenings. I really got crazy of it. I guess you all really don't know how many combinations exist on the preprocessing side. In the end I just had the feeling of wasting my time, but, it seemed I got there.
Now, yesterday, after the report of Johan and the disks still waking up, I realized that I never put the Copy to XX-Drive into the equation, so I sat down and tried to get that in. Allright, this day of work already wasn't enough because I already know it doesn't work properly (as said elsewhere), but the worst of it all is that it will REALLY take a week at least to again test everything. And I don't want to do that. What I do want to do is revert yesterday's changes, so I'm not in the complete blind of what you all might be encountering, while I worked so hard to not be blind. So ...
Russ, if the before version (0.9y) gives you the same problems, then nothing is the matter and the one month just hasn't been enough; I overlooked things and we will find which they are. But, if the before version does not give these problems (and this might count for Roy just the same), I will revert yesterday's changes in a few minutes - realize that I wasted a day (yesterday), but next proceed with breathing.
Generally you can well say that I shouldn't have started the Digital Filter thing (it is really this which has turned everythig upside down), but this may be because it looks like all sounds better without. Hahaha ... bad luck.
Oh well ... yahoo
* XxHighEnd-09-ya.zip (6358.43 KB - downloaded 580 times.)
« Reply #12 on: August 13, 2009, 10:09:32 am »
I shall have a play after nocturnal munchies and report back.
One other thing I noticed this afternoon is that if I queue up a single file ( and perhaps a few ), when it comes time to display the "mirrored back" panel, that the list contains entries from an album in a previous folder and otfen in a later folder. It's as if XXHE has looked at the folders before and after the track you are asking to play, and listed those also. This results in the ^^^ and +++ showing in the left panel. Weird. I'll try and take a screen grab to illustrate later.
« Reply #13 on: August 13, 2009, 10:49:37 am »
Roy,
Goodmurning,
Its not that space, but it is wrong anyway.
I tried a dozen of albums, no luck yet.
Did what you asked, untick "Start Engine3 during conversion"
No luck either.
Grtz
« Reply #14 on: August 13, 2009, 11:03:18 am »
Roy, can it be so that when you expect things to play, XXEngine3.exe is running indeed with just very low memory ? (check TaskManager);
This is what I saw myself yesterday at the attempt I reverted (and just talked about). If so, I'll have a small clue to start with ...
