November 23, 2024, 02:28:42 am *
Author Topic: Can xxhighend play flac files that do not start with numbers in their filename.  (Read 16269 times)
boidos
« on: August 05, 2009, 11:47:56 am »
Hi all,
My whole flac library is organised in individual folders with seperate files for each track.  The naming format for each track is simply the song name .   xxhighend only seems to be able to play back songs with track numbers in the filename..is there any way around this without renaming my whole libray.
thanks!
« Reply #1 on: August 05, 2009, 02:10:04 pm »
Hi there !
I am sorry, but I don't know what you mean by "only seems to be able to play back songs with track numbers in the filename";
XXHighEnd doesn't care about this *unless* some kind of error shows up !
The latter can happen because when it is recognized that no track numbers are in there, various means are performed to get them anyway, like obtaining them from a withgoing cue file. In this area things may go wrong, alhough I never heard of a problem with this. So :
Do you get an error message ? or otherwise, what exactly happens ?
« Reply #2 on: August 05, 2009, 02:40:59 pm »
it has also problems with for eg:
(CD1) (01) - trackname
() twice seems to be a problem.
boidos
« Reply #3 on: August 05, 2009, 02:47:12 pm »
for the tracks i ripped from cd myself..a track name might be for example...song.flac
i often get this error message
"the given paths format is not supported"
« Reply #4 on: August 05, 2009, 03:23:36 pm »
hmm ...
Can you please give the full path ? (as exact as possible)
Then I can mimic it.
boidos
« Reply #5 on: August 06, 2009, 12:01:59 am »
ok heres what i get
When simple search is turned on and I try to add the flac files for this Boards of Canada album, eg:  F:\music\flac\Boards of Canada - The Campfire Headphase\Into the Rainbow Vein.flac
I get this error popping up multiple times. (perhaps once for each track)
add trackdata
=13c- The given path's format is not supported
After which none of the tracks appear in my playlist
When simple search is turned off and I try to add the same tracks from the same album I get:
Get Coverart
The given path's filename is not supported. :15-F:\music\flac\Boards of Canada - The Campfire Headphase\Into the Rainbow Vein.flac
I get this error for each track name in the album popping up.
The items then appear in my playlist
When i try to click on the tracks in my playlist this error pops up.
Show Coverart from actual album
13 - The path's format is not supported
thanks I hope this helps!
« Reply #6 on: August 06, 2009, 08:45:57 am »
Thanks for your extensive outlay.
Somehow I have the feeling you do something I don't expect. So one more quesion please :
I assume your albums show in the Library Area; Now, when you click on an item in there (click the coverart) and click Load, this would be one of the normal ways I expect.
Doesn't that work either ?
Also, do you have a .cue file in such a folder, like that for "Board of Canada - The Campfire Headphase" ? and if yes, is it named "Board of Canada - The Campfire Headphase.cue" ?
If you have a .cue file indeed but it is named differently, try to rename it to the exact album name (and not xxxx.flac.cue ! see above example), and let me know whether that makes a difference.
(it is clear to me what happens now, like the 15-F:\... so it's only about how to do it)
Sorry for bothering you with these questions,
boidos
« Reply #7 on: August 06, 2009, 10:48:02 am »
Hi Peter, yes the albums show up in the album area, and I click on the album cover art to load the flac files into the playlist.
In the folder with the flac files is a txt file, a m3u file the coverart called folder.jpg.
There is no .cue file in the folder.
thanks again , I hope this helps.
« Reply #8 on: August 06, 2009, 08:07:03 pm »
Yes, it sure did. I found it, and at this moment it is almost solved. It will be in the next version.
This is about the situation that no means could be found to define the track number, and as a last resort the tag data from the FLAC file is examined for it. A comment in the program said "This has not been tested because of the lack of an example".
At this moment I am struggeling a bit with the possible formats the track numbering may be in there. The example I have says 01/25 02/25 03/25 etc. and while the slash hurts me to start with (this is a path separator), I am not sure what other means can be in there, and whether it is allowed to be user defined (at converting/ripping to FLAC). So, the /25 one wouldn't be interested in anyway, which leaves some unique identification of the track number. Maybe this ends up with the first two positions because I don't know otherwise. We'll see ...
Thanks for the help on this !
boidos
« Reply #9 on: August 06, 2009, 11:55:06 pm »
thanks Peter!  I am looking forward to be able to use your great program with my whole flac collection.
Page created in 0.123 seconds with 19 queries.
