November 24, 2024, 02:24:59 am *
Author Topic: XXHighEnd Model 0.9 (including Activation)  (Read 11270 times)
« on: June 24, 2007, 12:52:22 am »
Edit : Removed the zip because something is confusingly wrong in there.
From off this version (0.9) there is a new section "Undemo" containing a button to PayPal. By means of this button you can obtain an Activation Code for 72 euro.
If you don't want that : you can still use the Demo version (time restricted to 34 minutes on average) as long as you want.
Also see Install Notes and getting an Activation Key under "Getting an Activation Code" in there. Do read this !
Until it is kind of guaranteed that the Activation process runs without issues, XXHighEnd will maintain its beta status.
Careful !
At some stage you see that you will be asked to press "Continue" (see below for a dutch version of that screen). If you do not do so you won't receive your Activation Code by automation. If you do, a screen will follow containing your Activation Code, and within seconds you will be up and running.
So don't forget to press CONTINUE !!
Copy and paste the Activation Code in de appropiate field in the UnDemo section, quit the player and restart.
Please note : Currently Phasure is an "unverified" seller at PayPal, which is related to the procedure and an additional credit card which is needed (a credit card can be registered only once, and the one available was needed for testpurposes at another PayPal userid). Do not be afraid though.
Actually right now this is tested by selected persons. Until this red line is in here, do not proceed with the PayPal procedure !!
Current annoying issue with 0.9 and Engine #3 : The sound may stop with the message "Engine #3 did not start within the expected time" (similar). I hope to solve this asap.
Apart from the possibilty for Activation, there are no relevant changes opposed to 0.8c.
« Last Edit: July 09, 2007, 09:40:31 pm by PeterSt » Logged
