November 23, 2024, 01:53:21 pm *
Author Topic: What does Invert do?  (Read 8457 times)
« on: June 05, 2009, 03:49:21 pm »
I thought it would reverse the polarity, but it does not, so i just keep it off. In tracks where a sound is on the left side, click invert, and it will stays on the left side!
I like to wear my headphones switched and a reverse polarity (that works) would be really helpful. (i.e. in foobar works)
« Reply #1 on: June 05, 2009, 04:46:19 pm »
It reverses absolute phase ...
http://www.phasure.com/index.php?topic=782.0
beto
« Reply #2 on: June 05, 2009, 05:15:39 pm »
I think you should rename this option to Phase Invert, instead of just Invert, due to not being too clear to some and mainly new people as to what it does..
« Reply #3 on: June 05, 2009, 09:36:28 pm »
I wonder if you could add a polarity inverse... Happy
« Reply #4 on: June 05, 2009, 11:18:44 pm »
Are you sure you want *that* ? ... or do you mean left/right swap ?
Both is as easy to implement. It only takes quite some time to do it. Not if this programming would have been set up as normal programming should ... but that is not the case here. swoon
« Reply #5 on: June 06, 2009, 12:06:14 am »
L/R swap.
No hurry but I would like it.
