April 07, 2025, 02:18:09 am *
Author Topic: will not play hi-rez files  (Read 30660 times)
leifchristensen
« Reply #15 on: June 05, 2009, 11:45:01 pm »
true,but like a friend of mine, Gary Dews of Borderpatrol, says: if it sounds right,it probably is Cool
we´ll figure it out , eventually!
good night
best
Leif
« Reply #16 on: June 06, 2009, 12:00:02 am »
BTW: The music files are downloaded/purchased from Blue Coast Records, a 24/96 sampler album with GREAT, GREAT sound. A mix of small scale blues with very good performers in the tradition of Muddy Waters/Folk Singer. The best SQ I have heard from this kind of music. Highly recomended!
The rest of the story, Leif will tell himself. (It's a story with a happy ending).
leifchristensen
« Reply #17 on: June 06, 2009, 12:06:36 am »
what are you doing on the web? shouldn´t you be B/&%&)& your wife by now Wink
best
Leif"past 50" Christensen
« Reply #18 on: June 06, 2009, 12:24:39 am »
best
Hmmm. It's a hard choice between hi-rez and sex, but on second thoughts.......... Good night! love
leifchristensen
« Reply #19 on: June 06, 2009, 12:41:44 am »
traitor! Shocked
« Reply #20 on: June 06, 2009, 08:21:54 am »
Ah, I wanted those myself anyway. Production "within 24 hours", so no time to compress. Haha.
I will get them and let you know.
leifchristensen
« Reply #21 on: June 06, 2009, 03:59:41 pm »
they sound good,but AHHHHH soooo boring music,as often is the case with these audiophile releases
I couldn´t keep awake, so I´m back to redbook Louis Armstrong @Duke´s place Happy
who cares what format it is....it don´t mean a thing if it ain´t got that swing
playing on the spdif output via 10m cables from basement musicserver to Buffalo 9008 and all is well    very happy
imo
Best
Leif
« Reply #22 on: June 07, 2009, 12:49:54 am »
I disagree! It is true that "audiophile releases" with unknown artists often sounds boring, but this album is great musicianship. IF you happen to like simple rural blues. But, ok, let's be honest, I wouldn't spend $40 for this 12 track album, if it wasn't because of the 24/96 SQ   sounds good !
I truly enjoyed this album, and will play it again, from time to time.
leifchristensen
« Reply #23 on: June 07, 2009, 12:55:36 am »
good musicians but their repotoire is downright boring
ZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZ
if I had to listing to only this kind of music I would rather change my hobby to knitting!
IMO
best
Leif
komsansr
« Reply #24 on: July 12, 2009, 06:51:55 am »
Hi
At 1st .. I never posted in any forum .. sorry if i made some wrong
My system
OS : Window 7
Sound card on board : Realtek HD Audio Device .. ALC833.. specification
               HD Audio Headphone : out 2X44.1-192kHz, 24bit
               HD Audio Speaker     : out 8X44.1-192kHz, 24bit
               HD Audio SPDIF        : out 2X44.1-192kHz, 32bit
Playback Device from Control Panel : ..from advance tab..Max avialable bit and sample rate is 24bit@192kHz all
Audio File : wav format both 16bit@44.1kHz and 24bit@96kHZ
Audio Player : Foobar 2000 with WASAPI
               From system above, I could play all audio file I have
               With XXHighEnd, I could play all 16bit@44.1 file with #3 engine .. but couldnt for 24bit@96kHz file
               I tried to activate DAC test then. and for
                           Output : Speaker
                           Engine : #3
                           mode   : DAC test
               Result
               Start Audio Device Analysis Exclusive Mode support Speakers (High Definition Audio Device)
     Supported : 2|16|44100|176400|4
Not supported : 2|24|44100|264600|6
Not supported : 2|32|44100|352800|8
     Supported : 2|16|48000|192000|4
Not supported : 2|24|48000|288000|6
Not supported : 2|32|48000|384000|8
Not supported : 2|16|88200|352800|4
Not supported : 2|24|88200|529200|6
Not supported : 2|32|88200|705600|8
    Supported : 2|16|96000|384000|4
Not supported : 2|24|96000|576000|6
Not supported : 2|32|96000|768000|8
Not supported : 2|16|176400|705600|4
Not supported : 2|24|176400|1058400|6
Not supported : 2|32|176400|1411200|8
    Supported : 2|16|192000|768000|4
Not supported : 2|24|192000|1152000|6
Not supported : 2|32|192000|1536000|8
Not supported : 2|16|352800|1411200|4
Not supported : 2|24|352800|2116800|6
Not supported : 2|32|352800|2822400|8
Not supported : 2|16|384000|1536000|4
Not supported : 2|24|384000|2304000|6
Not supported : 2|32|384000|3072000|8
              this may mean that i cant play my 24bit@96kHz file with this sound card.
              I tried to test again with DAC test share mode ... and I set  bit and sample rate at 24bit@192kHz in playback device Exclusive Mode (with 16bit@44.1kHz file)
              Result
              Start Audio Device Analysis Shared Mode support Speakers (High Definition Audio Device)
    Supported : 2|24|44100|264600|6
    Supported : 2|32|44100|352800|8
    Supported : 2|24|48000|288000|6
    Supported : 2|32|48000|384000|8
    Supported : 2|16|88200|352800|4
    Supported : 2|24|88200|529200|6
    Supported : 2|32|88200|705600|8
    Supported : 2|24|96000|576000|6
    Supported : 2|32|96000|768000|8
    Supported : 2|16|176400|705600|4
    Supported : 2|24|176400|1058400|6
    Supported : 2|32|176400|1411200|8
    Supported : 2|16|352800|1411200|4
    Supported : 2|24|352800|2116800|6
    Supported : 2|32|352800|2822400|8
    Supported : 2|16|384000|1536000|4
    Supported : 2|24|384000|2304000|6
    Supported : 2|32|384000|3072000|8
                   I tried to play my 24bit@96kHz then at dac is 24bit 96kHz.. the file edit from 16bit@44.1kHz by Wavelab 5..
                   error : Endpoint Create Failed > The DAC does not accept this byte sequence
                   error : 2/32/96000/768000/8
                   error : Device cannot play
                   error : engine #3 did not start within the expected time
                   I tried to test again with DAC test share mode at 24bit@96kHz in playback device Exclusive Mode.
                   Result
    Supported : 2|24|192000|1152000|6
    Supported : 2|32|192000|1536000|8
                   And I tried to play the same 24bit@96kHz file at dac is 24bit 192kHz..
                   End
                   I have no more idea then and could not go further.
                   If u ll have any comment .. plZ
                   Sound quality of XXHighEnd s very nice and impressed me so much.
                   Sorry for my english.  It s not my native
Thk
komsansr
Thailand
« Reply #25 on: July 12, 2009, 09:13:06 am »
Well, let me tell you first that all looks the most thorough as can be, and you did/tried all very well. Hats off, also for your presented analysis !
(btw note the Shared Mode test is unofficial, and also unreliable, because although I stuffed it in for helping me a little in these kind of situations, it wasn't finished at the time (of this version)).
I never saw combintations like this, and I do *not* blame W7 for it. Could be, but I don't think so. It merely will be the audio device containing properties I do not anticipate upon sufficiently. Now, I know already that all these "HD Audio" devices can't be dealt with properly, and although this will be part of the base problem, this is just a new one I never saw before.
Coincidentally right now I am working on similar problems for a few days already (not specifically hi-rez related), and I guess I only quit that when I solved it. So far I don't see the solutions (read : I can't see what is wrong, but it still does not work), and exactly like in your case - in Foobar it works. The audio device not working I have at hand here, as I have at hand PCs with the HD Audio devices causing problems (as said, not the same HD Audio as yours). I guess when I found what's wrong with that, I will have solved your problem too. It is the only thing to do anyway, because I don't have such a device here.
I will let you know when I have some results, ok ?
« Reply #26 on: July 12, 2009, 11:14:10 am »
Allright, per pure coincidence of the timing of your post, this just have been solved (well, I said I was working on it Happy).
The coincidence is merely about the fact that this problem has been there right from the beginning, and now at last I found the culprit.
Please keep in mind : whether it works for your device just the same has to be awaitened, but I'm confident it will.
It will be in the next version (0.9y), which is hopefully there within two weeks.
« Reply #27 on: July 13, 2009, 04:39:02 am »
Does this mean you think you've got empirical and benchmark dac things working?  That would be a nice buggerboo to solve.  gl
« Reply #28 on: July 13, 2009, 05:47:50 am »
Yes ... although the Benchmark must be tested by someone first, in order to be sure.
