November 23, 2024, 11:36:59 pm *
Author Topic: XX 0.8c plays one track at a time  (Read 12135 times)
Jack
« on: June 22, 2007, 07:54:40 pm »
Hello Peter
0.8c will only play 1 track at a time for me with #3. The track bar stays on the far right, where the track ended. I can hit next and the next track will play. #1 & #2 work fine & play through the list.
Jack
« Last Edit: June 23, 2007, 07:09:12 am by PeterSt » Logged
« Reply #1 on: June 22, 2007, 08:16:02 pm »
If you quit XX, and try again ?
And if you ONE other time quit XX and try again ?
I'm experiencing similar, in fact from the beginning with #1. There I catured this very strange behaviour, and here (#3) I still must get a grasp of this.
So, 2 hours agoe I used 0.8c for the first time myself ... had the same as you describe, but then did as I said. No problems since.
You ?
« Reply #2 on: June 22, 2007, 08:27:51 pm »
One other thing :
When this happens (no sound), after 60 seconds of that you should get a message that Engine #3 did not start within the expected time.
Do you ?
« Reply #3 on: June 22, 2007, 09:13:45 pm »
Never mind ... shouldn't have said it ... it just went wrong with me ...
scratching
Jack
« Reply #4 on: June 24, 2007, 01:47:00 pm »
Similar problem with 0.9. It plays first track, stops, a short pause, then a message, "#3 did not start at the expected time" Hit OK & the next track plays. Then it's the same for each subsequent track. Good exercise, but I'd rather relax & hear the whole playlist!
Jack
Jack
« Reply #5 on: June 24, 2007, 01:54:03 pm »
Hello again
Just read your previous post fully, and see that you already know the above, I'll leave you in peace with it!
Jack
« Reply #6 on: June 24, 2007, 02:02:58 pm »
It's ok Jack. And better, I solved it.
I have some other issues now though. I hope to upload a new version this afternoon.
Jack
« Reply #7 on: June 24, 2007, 03:27:31 pm »
Cool, I'll be back later....
Jack
