November 23, 2024, 05:21:11 am *
Author Topic: Changing Wallpaper in attended mode playback  (Read 19536 times)
« on: May 30, 2009, 09:01:41 pm »
Why do You change the Wallpaper in attended mode? Better to keep the windows background I think!
Sometimes for testing purposes I want to play in attended mode.
Johan
« Reply #1 on: May 30, 2009, 09:02:51 pm »
its a setting " show as wallpaper" untick this
« Reply #2 on: May 30, 2009, 10:31:47 pm »
I thought this was only working for unattended mode. 95 percent of the time I'm playing in unattended mode. I don't want to untick every time for attended mode this tickbox. I think this setting should only work for unattende mode.....i think?! What is the purpose to show this wallpaper in attended mode?
« Reply #3 on: May 31, 2009, 07:30:30 am »
I'm not sure Johan ... Happy
And I also thought it can't harm with the checkbox you have for it. But I guess I can make another checkbox "Unattended only" ?
« Reply #4 on: May 31, 2009, 09:14:06 am »
.......another checkbox "Unattended only" ?
'Sounds' ok to me!
« Reply #5 on: May 31, 2009, 10:33:28 am »
I think I'll use this thread to ask for...
If I don't have a "Back" .jpg, could I get a tic box to not have you generate a mirror image of the folder.jpg and display song titles?; just want it to show a front cover like was done before you added the back cover? ...don't ask me why, I don't want to look too crazy here ...
« Reply #6 on: May 31, 2009, 01:35:45 pm »
'Sounds' ok to me!
I'd like that too Happy
« Reply #7 on: May 31, 2009, 02:54:15 pm »
Yea, I think Johan was the first not to like it as how it is now. But I never got around to it. Obviously it is possible.
« Reply #8 on: June 01, 2009, 10:21:44 am »
Could you reset the Wallpaper after unattended playback. Now I  need to close XX to get the Windows background to start e.g. Programs via Shortcuts.
Johan
« Reply #9 on: June 01, 2009, 10:43:17 am »
I'll look into some improvement here.
You know about the small "I" button, right ?
« Reply #10 on: June 01, 2009, 12:42:47 pm »
Hi Peter. Don't know if JohanZ knows about the small "I" button, but I sure don't. Appreciate an explanation. Thanks.
« Reply #11 on: June 01, 2009, 02:05:46 pm »
...Don't know if JohanZ knows about the small "I" button
I knows about the 'i'-button! But it's still difficult to recognise the shortcuts. And why to keep the background when the playback sessie is finished or stopped. (Pause remains the background)
Johan
« Reply #12 on: June 01, 2009, 04:14:07 pm »
Oh, this is nothing related to the Wallpaper, but the small "I" button on the main form brings back (or removes) the Desktop Icons. And you'd need those in the Attended Playback situation when playback stops but XXHighEnd stays, and all icons stay away in that situation.
But I'll change it.
« Reply #13 on: June 18, 2009, 05:16:28 pm »
Johan
Done, per an additional setting (next version).
Johan
Also done (also next version  Happy).
In fact, when everything is gone, pressing Pause/Stop brings it back now.
heat It wasn't even easy, because of the so many combinations. heat
I think it is better now.
« Reply #14 on: August 13, 2009, 12:15:24 am »
Does it work in 09y? What are the parameters?
Finishing after the last track in unattended mode, reset the wallpaper (back to windows)
In attended mode You don't have to change the wallpaper. You don't need it in attended mode!
