November 23, 2024, 08:29:27 am *
Author Topic: Music files on OS harddisk  (Read 29283 times)
« Reply #15 on: June 01, 2009, 02:29:00 pm »
...what would be the best way to see all my albums in the XXHE Library?
Create a Gallery / Music folder and copy all the Albums via XXHighEnd in it!
Eric
« Reply #16 on: June 01, 2009, 03:21:26 pm »
Johan,
Thanks, the area of Galleries is something I haven't explored yet. What does your advice imply in terms of simple instructions?
Eric
« Reply #17 on: June 01, 2009, 04:37:30 pm »
Johan, allow me ...
Eric, look below;
What you see is (a part of) the list I have for physical music files on a drive. I: in my case. The albums in that list are selected by normal Windows means of selecting (click, ctrl-click, cltrl-shift-click etc.). Now do rightclick on one of the albums, and choose Add to Gallery.
At clicking Select, you will be asked for a "Gallery folder" to put the selected albums in. This is just a normal folder, and you can create it from there. It is the advice to have the Galleries at the OS disk (say, drive C:). You can create a root like "Music", and under that everything you want. Could be Classical and Jazz etc. etc. Anyway, whatever you put in there, and no matter from what drive it came, it will be accessible via that Gallery root. For that, set the Music Root in the Settings Area to the Gallery root folder. From there you can choose for your Classical or Jazz etc. no matter where it really resides, and you can also ask for everything from the Gallery root itself (via the Library Area). In the latter case you will have all albums at hand in one list. In the second picture I chose my Gallery root folder (see at the bottom, I have it named "Galleries"), and because of that the albums are shown with the preceeding Gallery folder name "\Classical\". Because this is there, it allows you to select all classical by just typing that, so you'd end up with only classical again, as if you had chosen that Gallery folder.
Just practice a bit; it won't harm. Many more things can be done, but this gives you a start I hope.
(and don't start moving Gallery folders, because the support for that is not in XX yet nea).
Eric
« Reply #18 on: June 01, 2009, 05:03:34 pm »
Thanks Peter
this opens up a new area of fun for me.
Moving all my albums to the gallery is going to keep me busy for a little while. The fun part is that it forces me to revisit my music collection.
Ciao, Eric.
« Reply #19 on: June 01, 2009, 11:03:58 pm »
Thanks Peter
Ciao, Eric.
Yes, it DOES take long Happy
« Reply #20 on: June 02, 2009, 03:57:04 am »
Keep in mind, creating Galleries is not moving the actual wav (and it's big size), just a reference to where the wav is.
Once you have your wav/music file folders set up how you want, creating the commiserate gallery for them doesn't take any real time.  Just the time to organize how you want?  If everything is a mishmash of music on your wav/music files, then ya, the organization of your galleries will take long ... noobie rippers take heed, organize right from the start.
Page created in 0.104 seconds with 19 queries.
