April 08, 2025, 03:35:48 pm *
Author Topic: NO sound - have used "installation guide for dummies"  (Read 10206 times)
Tore
« on: May 27, 2009, 06:15:05 pm »
I`m new with this and have now done my first download and payed for it. But i have no sound, have tried USB and SPDIF to the DAC. The dac i working when i use a DVD-player as a drive.
Everything looks OK, the xxhighend player starts playing but no sound.
I have not installed the Hotkey yet and i was answering yes insted of no under the installation when the questinon "load previous settings" came. Because of that i deleted the downloads and tried again.
Now the player is missing the data under "info" and the "play" knob is  inaccessible .
Can someone help me?
« Reply #1 on: May 27, 2009, 07:29:31 pm »
Hmm ...
Did you slide the volume up ? (when you use a pre-amp, just all the way to -0dB)
Did you choose the correct Sound Device in the Settings Area ?
And how is your Sound Device called ?
Btw, do you use Engine#3 and Vista ?
On the Play button and the Info ... is there a track loaded in the Playlist Area ? I think this not being the case can be the only reason for the Play button being inaccessible and the Info data not being there.
Right now I don't know any further questions, but after you answers I may ... Happy
We will get you there !
Tore
« Reply #2 on: May 27, 2009, 09:39:57 pm »
Thanks for help!
Did you slide the volume up ? (when you use a pre-amp, just all the way to -0dB) : Yes
Did you choose the correct Sound Device in the Settings Area ? Do you mean Output? There i have choosen Primary Sound Driver. The other choices is different HDMI output and one RCA. No USB or SPDIF
And how is your Sound Device called ? What do you mean?
Btw, do you use Engine#3 and Vista ? Yes
On the Play button and the Info ... is there a track loaded in the Playlist Area ? I think this not being the case can be the only reason for the Play button being inaccessible and the Info data not being there. It is not posible to choose a track now when the Play button is not working. But i think it is a track loaded, ervery time when i start the xxhighend player the same track is there
« Reply #3 on: May 27, 2009, 10:27:57 pm »
Hey Tore,
I think you need help, unhappy
But if you want help you need to be more specific
Describe your set-up as in what pc with what soundcard -->>what connection--->> what dac and settings
Playing a what kind of file from where.
If i can't help you Peter will, but describe your system layout
or maybe use those specs in your forum appereance. your specs under every post you make
roy
Tore
« Reply #4 on: May 27, 2009, 11:10:38 pm »
Hi Roy!
Does this help? Dell Studio D055401 PC, Intel Pentium Dual-Core E5200 processor , Vista Ultimate, DDDac with USB/SPDIF, Integrated amp
I`m at work and can`t give you more
« Reply #5 on: May 27, 2009, 11:17:37 pm »
I think in this area something is wrong;
You have a soundcard (sound device) somewhere, right ? it is on the motherboard or a PCI card, or anything that you recognize as to which your DAC is connected (when means of SPDIF). Now *that* device must be chosen in the Settings Area.
When you rightclick on the speaker icon at the right in the taskbar tray and choose "Playback Devices" your soundcard etc. must show up in the list. If it does not, something is wrong.
When the DDDac is USB connected you should be able to find "USB Loudspeakers" amd when it is SPDIF connected I actually don't know. But anyway something in which the DDDAc is recognized.
I hope this will take us one step further !
« Reply #6 on: May 27, 2009, 11:34:08 pm »
or just disable what you don't need, leaves you only with one device left,
 like in the pics thats the one to be chosen in xxhe.
see pics audio device must be the same
Tore
« Reply #7 on: May 28, 2009, 01:15:15 am »
Thanks!
I have to come back to this, i`m offshore on job and is not home before 10. june
