November 23, 2024, 09:01:04 pm *
Author Topic: New error ;)  (Read 20760 times)
« Reply #15 on: June 01, 2009, 09:13:56 am »
The Galleries folders are created by XX (on your command) and contain the meta data with .mta files ...
If you didn't (order for Galleries) I misunderstood the whole subject. I will look into it better tomorrow. sleeping
Where are they supposed to be?
« Reply #16 on: June 01, 2009, 10:48:52 am »
Before making it too difficult ... I now see in your error-4 picture that you stuffed "(WAV)" in the name; is that correct ? if so, that for sure creates problems, probably this one.
If you had created Galleries I think you would know. But if so, they are just normal folders on the drive you created the Galleries. For that matter, your error-4 picture may show a Gallery root of FLAC (but I can't see whether it's a Gallery or a real music folder), and that FLAC folder would just reside on disk.
Let me know about the (WAV) thing ...
« Reply #17 on: June 01, 2009, 01:29:44 pm »
The (WAV) is either in the artist folder (in which are the albums) or after each album. It's there to remind me to convert them to flac and then edit the tags.
If i do the conversion first, this problem will disappear? Because i have to do it sooner or later Happy
« Reply #18 on: June 01, 2009, 02:33:45 pm »
I removed the "()" and now they are working Happy
