April 05, 2025, 01:02:43 am *
Author Topic: Losing Undemo rights after reinstall  (Read 5509 times)
Eric
« on: May 17, 2009, 10:45:25 am »
Hello Peter,
I folllowed your installation guide for dummies to reinstall my XXHE in the correct way and, being a dummy, I seem to have lost my Undemo rights.
Please advice, thank you.
Cheers, Eric
« Reply #1 on: May 17, 2009, 10:58:04 am »
Ah ... that is GOOD that this happened to you, because I planned to explicitly mention that the XXHighEnd1xx.dat file must be moved at a next install (hence upgrade). So I will stuff that in the text right now ...
For you for now, copy that file to your nex install folder, and everything will work again.
And ehh, GOOD or not, sorry it happened !
