« Reply #45 on: October 25, 2009, 01:38:22 pm » |
Johan, where is your XX Log file ? I did not found them. I do a new attemp to create this situation this evening. XX setting is always "copy to XX drive" I will check this. I only work with normal .wav files
« Reply #46 on: October 27, 2009, 06:30:35 pm » |
Difficult to reproduce this messages, but today all the messages for another cd: "Music file does not exist" message Application crash.
1 What i did was loading the playlist and play. After a few tracks pause and again a play command. I don't know if this is relevant. 2 At a certain moment i hear the external drive activated 3 small brake in the music but music keeps playing 4 after the second time I'll wait and switched the external drive off 5 music keeps playing, untill a fraction before it end's 6 message "Music file does not exist" This message disappears automatically within a couple of minutes. 7 XX stops 8 Application crash
Settings "Copy by XX drive standard", for me it is D: drive
See attachment all logfiles
« Reply #47 on: October 27, 2009, 07:28:52 pm » |
But to be clear ... was your Copy to XX Drive always on ? I mean, thus your previous posts are about when this was set to On ?
Also, can you please lookup the XX log file which is one "version" older than the one you attached ? So, the one you attached was after XXHighEnd restarted, while there must be another one from when you started playback. It should have a time (in its file name) of around 17:38 (and not 17:53 which is the one you attached).
Thanks ! Peter
« Reply #48 on: October 27, 2009, 08:54:05 pm » |
But to be clear ... was your Copy to XX Drive always on ? I mean, thus your previous posts are about when this was set to On ? YES, its alway on. I don't like the sound of the external drive. It should have a time (in its file name) of around 17:38 See Attachment
« Reply #49 on: October 28, 2009, 08:50:56 am » |
Hi Johan,
Please help me with one tiny thing more (only takes 2 minutes);
Load that same album (Mike Manieri), switch On "Start Engine3 during conversion" and press Play, the same as you did it yesterday. When all tracks have been processed and XXHighEnd has disappeared, please attach the XX log file of that.
I don't expect this "Start Engine3" to help, but it helps me comparing with what I always see in my own log files. But also, it is the only thing you have set different (and may matter) compared to my own situation. And in your case it just takes the files from I: ! By now it is almost more interesting how it is possible that you can play a whole album without that drive attached. So there is more (and it could be just playing FLACs or tracks to otherwise convert).
Very strange so far ...
« Reply #50 on: October 28, 2009, 08:47:04 pm » |
On your request, See attachments Load, Play, Stop
« Reply #51 on: October 29, 2009, 11:55:54 am » |
I don't expect this "Start Engine3" to help But it does anyway. I don't know why yet, but you'll see if you try it with this setting, it works (at Unattended of course).
« Reply #52 on: October 31, 2009, 12:12:31 pm » |
And ?
« Reply #53 on: November 01, 2009, 05:37:24 pm » |
And ? Indeed I have the impression that the setting "Start Engine3 during conversion" solves the interrupptions. Although this morning I did hear disc-activities. I Switched the external drive off and guess ...again a message "Music file does not exist on I:\\music\jazz (see attachment) The setting "Start Engine3.." is responsable for missing the first OSD Text after a play command. At the second track the album and track information is ok. So when i unticked the option "Start Engine3" the OSD Text information will be presented at the first track. This was the reason I unticked this option in the first place. So yes it seems to me until now that "Start Engine3" works.....but why do I have the diskactivities while I use Copy to XX..." (this morning I had one interruption) Log file are attached
« Reply #54 on: November 02, 2009, 10:27:11 am » |
Hi Johan, This is the pure coincidence of an internal error occurring, which by *another* coincidence this error does not show to you (but shows in the log file). I think I saw that before in your log files. I should be able to solve that ... (  )
« Reply #55 on: November 02, 2009, 01:04:04 pm » |
I should be able to solve that ... Do you mean these diskactivities during playback. .....but why do I have these external diskactivities while I use "Copy to XX..." during playback in unattended mode? Did I do something wrong when I added the music to the Gallery? Wrong pointers? I have the impression that XX triggers this external disc-activity.
« Reply #56 on: November 02, 2009, 01:35:30 pm » |
The error implies the disk activity. Or at least that is what I think without having looked in the program yet.
« Reply #57 on: November 08, 2009, 02:50:44 pm » |
Indeed I have the impression that the setting "Start Engine3 during conversion" solves the interrupptions. Although this morning I did hear disc-activities. Today again the interuptions in the sound! Sometimes every minute external disc activities.
« Reply #58 on: November 10, 2009, 12:26:23 pm » |
This disc activity thing keeps me busy for a while. I had always the impression that it starts after 4 or 5 tracks of a record. Yesterday I was thinking about that and i realise that I frequently use the pause command and followed by a play command again. I did a clean start of XX load a record in the playlist and play unattended. After that I switched the external drive(s) off and all plays ok without a message. After switching the drives on I did load again a record in the playlist and give a play command. After some tracks I give a pause command and play again (i am not sure if works for the first time,..) the next track I hear external disc activities. I have done this test again with the pause command. After the first notes I switched the external drive off and during that number I get the message "Music file does not exist on I:\\music\jazz . I am not 100% sure about this but its a direction I am thinking about.
Second thing I have noticed is that when you give a play command after a pause command , it looks like all the next tracks are loading again from the external drive (I hear external disc activities!!!). I have test this by switching the external drive off after a pause command and then a play command again. Then you get this message "Music file..I:\\.." again. This works also when you give a stop command during playback, followed by a play command. in my opinion this reload of the wav. files is not necessary because all the wav files are still in the XX directory. Only switching XX off clears the wav. files in the XX directory.
Last thing. Starting XX it shows the old playlist. I have the impression that when I select a track it also activates the external drive when it is in a powersave condition. Is that necessary?
Could you increase the text area for a reply, because I get a strange behaviour when I type more text then there is space for it?
Regards Johan
« Reply #59 on: November 10, 2009, 06:27:57 pm » |
Hi Johan, Thank you for spending all the time on this, but I guess it is not for nothing ... You will be correct ! I must look into everything whether is is solveable in an easy fashion. Maybe not ...  (outside the currently needed parameter of course, that sure will be solved in the next version (0.9y-5). Also, by now I guess it is a psychological thing, so now you know what causes it, maybe this does need to be solved at all ?? Again thanks, Peter
