November 23, 2024, 11:05:27 pm *
Author Topic: Sometimes no sound with #2 and Realtec ALC883  (Read 9614 times)
« on: June 22, 2007, 08:54:18 am »
In the last versions of your Software I sometimes get the following errors during playback:
"Out of memory.....if you have 2 GB of internal memory, please notify the developer about your soundcard" I am using SPDIF signal from the on board sound card Realtec ALC883 HD Audio
Hi Johan,
Your "sometimes" refers to tracks which are just over 6 minutes and more.
I assume that these tracks play with #1 (please let me know !!) .
I can expect that when you play an over 6 minute track with #1, and you alt-tab to another application - and back to XX, the sound stops (please let me know !!).
I think that this is coud be a bit perfect driver for XP (if you know, please let me know).
Now, firstly, there are so many issues with this chip/drivers, that it's hard to find my way in Google. I hope you can do it yourself ?
Try to focus on the driver being bit perfect, which you should NOT use, because it will make all instable (e.g. what you encounter now). Of course, you could use it for tracks shorter than 6 minutes.
If they exist, try to focus on signed drivers. You might search for drivers for Vista for more easily finding them, and they may contain data for XP, or you might have ended up on the proper webpage anyway.
Note that these will not be bit perfect then, but it's really one way or the other (or Vista/#3 Happy).
Please note that at your Google search you will never be able to locate the "error" you have at hand here, because of the way I treat things (which just nobody does).
Since I expect, with your current drivers, that #1 just runs (but not stable for alt-tab and back as indicated above), this might be your best bet, as long as you don't use/touch the PC during playback. Of course all depends on my estimations (above) being correct.
« Reply #1 on: June 22, 2007, 11:05:31 pm »
Hello Peter,
I don't use #1 because its limitation of 6 minutes. I am a lover of music of the 70th. So it often the music takes more than 6 minutes.
I get the error in #2. When I have started the player, I never touched it.
During playback the music suddenly stops with this error.
I'm using the official Realtec ALC883 drivers......are there other drivers?
When I select a other Output device and I switched XXHighEnd off and start it again then it don't remember the last setting!
Johan
« Reply #2 on: June 23, 2007, 12:15:33 am »
No no no ...
In my first post above I am suggesting you should use #1 (because I think that that works), and I am STATING that #2 doesn't produce sound with a track over 6 minutes.
So ... is that (my) theory, or do you KNOW.
If the latter, you should say : "#2 behaves the same as #1"  ... and I don't think that is the case ...
Difficult and confusing ... Happy
Hmm ... #2 (and #3 currently) uses the Primary Device anyway. With #1 I don't know anymore whether I made it remember it (but it theoretically can do it anyway).
« Reply #3 on: June 23, 2007, 01:15:16 am »
.............. blush1 You are right, it must be friday. I have test it! But #2 plays tracks of 11 minutes. So I forgot the 6 minutes limitation.
So that problem is solved!
Johan
« Reply #4 on: June 23, 2007, 07:07:38 am »
Unimportant :
Quote from: PeterSt
Can you please tell which Engine and OS you use, and whether you Double or Upsample (yeah, the last both logically follow from something, but that's exactly why I ask).
and
Quote from: JohanZ
I am using engine#2 with double, Windows XP Pro.
I think here the confusement started, *also* because I split the topic into two, and the above was from the original etc., blablabla.  Happy
Then I added this to it :
Quote from: PeterSt
With which I say (suggest) it just does (or should) work with #1, and I say this because (you say) it does not with #2 (this would be the e.g. Fireface situation with MME drivers). But as you say now : it does work with #2, this implies it does not with #1.
Everybody dizzy ?
Next time I'll ask questions more, and suggest less. thankyou
Page created in 0.37 seconds with 19 queries.
