November 23, 2024, 04:37:42 pm *
Author Topic: flac not works!  (Read 6915 times)
Kohlrabi
« on: April 07, 2009, 09:04:41 pm »
hello again I'm having trouble with flac audio files. when I add them to playlist and click play I cannot here anything. NOTHING! I am thinking maybe the files are too bad I only have 16 bit 44 khz flac here, can someone help me with some 24 bit 96 khz or better 32 bits or more?!!
« Reply #1 on: April 07, 2009, 09:50:29 pm »
Well, first your normal 16/44.1 should be playing, right ?
You might send me an example, so I can see what is wrong with it. Here : http://www.phasure.com/index.php?topic=721.0
If you can do that, I will let you know !
Kohlrabi
« Reply #2 on: April 07, 2009, 10:14:40 pm »
I already uploaded you the file, but now I can play it suddenly. I think it is because I had changed Q5 slider last time to a too small value, now it is Q5=15 and it works!
thank you!
« Reply #3 on: April 07, 2009, 10:20:34 pm »
Possibly that influences. I will test it here anyway and let you know. Happy
