November 24, 2024, 02:08:34 am *
Author Topic: Strange but true  (Read 20823 times)
« Reply #15 on: April 09, 2009, 01:46:56 pm »
Thank you very much for testing it like that;
There is a special provision for WMP in XX somewhere, and I guess I killed it by accident. Now I know where to look.
Again, thanks.
« Reply #16 on: April 09, 2009, 07:02:00 pm »
Yes I did. There was even a comment "is this correct ?" next to it.
Solved in the upcoming 0.9x-7.
Btw caused by "your" format switching requirement, which I rechecked and still works. Happy
« Reply #17 on: April 09, 2009, 08:34:36 pm »
So glad to hear that the format switching will be solved in "7'. Been making playlists for a long time and they have both 16/44.1 and 24/96 traks completely mixed.  Happy
Not sure what you are refering to with this: "Yes I did. There was even a comment "is this correct ?" next to it.
Solved in the upcoming 0.9x-7." Yes you did what?
BTW all hotkeys have been working for several days. A reboot fixed that problem.
« Reply #18 on: April 09, 2009, 09:14:41 pm »
"Yes I did".
And in the program at the pace concerned I even wondered whether what I eleminated was right.
So it ws not.
So, that solves the problem of WMP rips which create a non-conform header.
« Reply #19 on: April 10, 2009, 12:52:35 pm »
Thanks again, Peter. It does still seems strange though that none of the other WMP  ripped albums that I've played have had this problem. Dylan's Tell Tale Signs was released last fall. Maybe there is something in the newer WMP rips that's different? Whatever it is I certainly look forward to the fix.
Page created in 0.168 seconds with 19 queries.
