November 23, 2024, 05:10:39 am *
Author Topic: ESI Juli Analogue P/B with AE3  (Read 7154 times)
tricka
« on: April 06, 2009, 05:39:51 am »
Hi everyone
I guess this is directed at Russ & Peter.
I can playback via Audio Engine 3 via my ESI Juli@ spdif but not via my ESI Juli@ analogue; the latter only being available with AE2.
I have the latest drivers.
Any thoughts?
Best Wishes
Andrew
ps log below - whoops first log I am trying to do a dac test with a 24/48 file...
* XX-20090406-134254.log (28.42 KB - downloaded 466 times.)
« Reply #1 on: April 06, 2009, 07:25:06 am »
Hi Andrew, excuse be, but here at the other end, I personally don't get what is not working or what you want, which propably is because, well, I don't know what you want to do with the card.
The 24/48 confuses me even more (is that related ?), and btw, what you propose as a "DAC Test", is not. The DAC Test is the one but last choice under "DAC Is" and is to be performed with 16/44.1 files.
But then I'm dutch ... swoon
So, please rephrase everything, and don't assume anyone knows what AE2 is. Or AE3. Or P/B. And mostly :
Where / what / how/ why / messages ?
And I don't try to exaggerate !
In any case, might it be just "no sound" and "time cursor not moving", get yourself the latest here.
« Reply #2 on: April 06, 2009, 09:11:20 am »
Hi everyone
Any thoughts?
Best Wishes
Andrew
HI Andrew,
IF you have the SPDIF working correctly which I presume you have,  simply go to the Juli@ control panel, and press the 'MON' button just beneath the 'S/PDIF OUT' words. The button should turn orange. You should now be getting output via the analogue channels.
The Juli@ card is now monitoring the SPDIF channel ( which is still operating in Exclusive Audio mode ~ check by clicking the mute function ~ play should continue unheeded ) and converting it via its internal DAC's to analogue.
Job done!
See if that works.
tricka
« Reply #3 on: April 06, 2009, 12:29:07 pm »
aahhhh...thanks Russ.
Good as gold now.
Sorry Peter ...guess I was clear as mud. Made sense to me  wacko At least Russ deciphered it. Must be an Australian thing he he
Interestingly I changed IC's to some shielded and grounded ones and now have a very low noise floor coming through the 96 db speakers. So am playing with the (unbalanced) analogue out. Very nice it is too. Plus avoids the spdif issue.
Thanks
Andrew
