November 23, 2024, 08:34:06 am *
Author Topic: No sound anyone ?  (Read 7692 times)
« on: April 04, 2009, 07:34:54 pm »
All,
There is one user with the situation the soundcard won't get selected for Engine#3 (XXHE 09x-6a errors). So far I do know where it goes wrong, but there seems to be no reason why.
Is there anyone out there who can't get sound with Engine#3 from 0.9x-6a or 0.9x-6b ? If so, please report this; possibly similarities can be found.
Thanks very much,
Josef
« Reply #1 on: April 05, 2009, 12:47:11 pm »
I get same symptoms as JohanZ - no sound, progress indicator stays put and after a while an error message saying Engine#3 did not start within expected time. Version is 09-x6b (same happened with x6a).
Previous version (09-x5b) works.
« Reply #2 on: April 05, 2009, 02:22:28 pm »
Hey, thanks !
Coincidentally this has just been solved. You might try the below XXEngine3.exe. Stuff it over a 0.9x-6a or -6b folder. It should work then ...
* XXEngine3.zip (62.36 KB - downloaded 533 times.)
Josef
« Reply #3 on: April 05, 2009, 02:46:10 pm »
Yes - it works now.
