November 23, 2024, 02:44:23 pm *
Author Topic: CD's won't play ?  (Read 21464 times)
0 Members and 10 Guests are viewing this topic.
« Reply #15 on: March 28, 2009, 06:50:01 pm »
This must be that short name problem again. So, even with the Wall Paper shut off, the path to them are stored by means of their Short Name. This by itself is only needed for the  "Copy to XX-Drive" feature, but it is needed anyway now. Sorry ...
If you could test and switch on those Short Names ...
Do you have any reason to shut them off ? (I'll listen Happy)
« Reply #16 on: March 28, 2009, 07:13:04 pm »
no reason to switch them off,
but these are standard mods for vista and xp
to boost op performance.
but if xxhe uses them then ill switch them on
"its all about the music" hehe
Disable 8.3 filename creation:
The NFTS file system is set to automatically create a "short filename" for any file considered a "long filename" in Windows. This is done so files are compatible with old 16bit legacy applications. Microsoft admits the creation of 8.3 filenames can degrade your file system performance. To disable 8.3 filenames for future files you will need to open "regedit" and navigate to: "HKEY_LOCAL_MACHINE\ SYSTEM\ CurrentControlSet\ Control\ FileSystem" and find the DWORD "NtfsDisable8dot3NameCreation" and set its value to 1.
To disable 8.3 filenames for existing files you will need to open a command prompt and type "fsutil.exe behavior set disable8dot3 1". Source: Microsoft.
you have to switch them to 0
roy
roy
« Reply #17 on: March 28, 2009, 07:15:12 pm »
But I wonder how that works for existing files. And *if* it works ...
« Reply #18 on: March 28, 2009, 07:19:06 pm »
yep i now what you mean
w'll see
i'll try it tommorow
i''m now going to use your xxhe to enjoy some music for now
grtz whistle
« Reply #19 on: March 28, 2009, 07:39:22 pm »
And read your email ! innocent
