« on: March 27, 2009, 07:43:35 am » |
I'm now set-up for about 6 weeks. The sound is great for now (it takes lots of time to get things to work your way) and it takes lots and lots of time listening.
I have a Q:
I have about 800 cd's on my hdd but about 10% to 20% doesn't play in XXHE. and they are all hq single wav files in album folders.
and what is "invert" there is no balloon tip there?
grtz EINDHOVEN GEKSTE
« Reply #1 on: March 27, 2009, 08:04:19 am » |
About the Invert ... hey, you are right. No ToolTip. Pwew. It means switching absolute phase (so for both channels + and - switch). About the albums ... strange. Of course I want to know what you ripped them with, but in the end I will need an example track. Can you send me one ? -> http://www.phasure.com/index.php?topic=721.0I will make them work ... I guess.  Good to see you happy ! Peter
« Reply #2 on: March 27, 2009, 08:43:36 am » |
Ok, downloading it right now. I'll remove the post when I have it.
« Reply #3 on: March 27, 2009, 09:29:46 am » |
But EINDHOVEN GEKSTE,
It just plays here ?
Can you send me all the 100 CDs which don't work in full so I can try them ? hehe No, just kidding.
But I guess you don't have enough memory maybe ? How much do you have ? Edit : yeah, 6GB according to you sig ...
« Reply #4 on: March 27, 2009, 09:37:15 am » |
having 3gb of ram now 4gb originally but went a little to far with overclocking so i lost one. next week corsair 6gb.
« Reply #5 on: March 27, 2009, 09:39:55 am » |
Ok, but do you get any error messages ?
Well, you could set your logging on, and post the X3 as well as the XX log file. But I'm not sure whether I can see anything. We'll see.
« Reply #6 on: March 27, 2009, 12:48:10 pm » |
no error messages just refuse to play at all we'll see indeed there were no others with the same problem?
same favorite album are in those 10% to 20% would like to hear them eventually on xxhe
grtz roy
« Reply #7 on: March 27, 2009, 01:25:09 pm » |
Where are your log files ??
« Reply #8 on: March 28, 2009, 03:50:05 pm » |
ok peter, log en x3 ik hoop dat je deze bedoelt
« Reply #9 on: March 28, 2009, 04:01:22 pm » |
The XX file is ok, but the other should be the X3.....log file from the same directory. And I like to see it (but a first problem is already shown ...).
« Reply #10 on: March 28, 2009, 04:06:38 pm » |
Can it be so that with a previous version you didn't have this problem with the same CDs ? (better not try it right now, because you might get stuck). It looks like you have the same problem as here : ChangeWP errors.
« Reply #11 on: March 28, 2009, 04:21:59 pm » |
yes i had the same problem with all versions. but 1 time it did play this album but vista crashed on me serveral times so i did a clean install so i don't no the versions or settings anymore
about wp-change i have the same problem and think i unticked the "show wallpaper" button. and thought the problem was over. I only have a log file from another album because x3 is created upon files "that did play on x3" correct me if i am wrong !@!
roy
« Reply #12 on: March 28, 2009, 04:28:29 pm » |
because x3 is created upon files "that did play on x3" correct me if i am wrong !@! Ah, if that is your observation, that is important to know just the same ! Further, same problem on the short names. Thank you Roy.
« Reply #13 on: March 28, 2009, 05:44:46 pm » |
a made a new folder and copied the album that didnt play to the new folder and named it ""aaaaaa" and now it plays just fine.
« Reply #14 on: March 28, 2009, 06:10:01 pm » |
when a put the images in the folder it goes wrong and wont play.  without images in folder it plays fine!
