April 19, 2025, 09:39:22 pm *
Pages: 1 [2] 3  All
Author Topic: ChangeWP errors  (Read 34561 times)
« Reply #15 on: March 28, 2009, 07:13:19 pm »
I'll see if method described on http://support.microsoft.com/kb/Q121007 works to undo the change....
Uhmm ... I guess not. That is for DISabling it. yes
Josef
« Reply #16 on: March 28, 2009, 08:01:11 pm »
I can confirm that method to disable 8.3 filenames also works to re-enable them.
Of course, after rebooting for NTFS to re-initialize itself, it will work only for files created from then on - so I had to copy all music files...
But hey, important thing is that now the problem is solved: all error messages are gone and cover art can be 'wallpapered' as well - tnx Peter for trying to help and to audiodidakt for the hint!
« Reply #17 on: March 28, 2009, 08:11:40 pm »
hey josef,
what do you mean by
"so I had to copy all music files..."
do i have to copy all files to different folder
grtz
Josef
« Reply #18 on: March 28, 2009, 09:10:35 pm »
that's what i did, yes - this will make sure NTFS creates 8.3 names...
simply 'touching' the file to update date/time or 'moving' it apparently does not work...
« Reply #19 on: March 28, 2009, 09:21:59 pm »
600 or 700 gigs
but yep the problem is solved
with a little teamwork here !
how are youre listing experiences with xxhe josef ??
grtz audiodidakt
Josef
« Reply #20 on: March 28, 2009, 10:21:57 pm »
to be honest I was extremely skeptical of XX: I was used to 'old' foobar over ASIO and did not know about XX at all until I noticed that I am not able to listen to music anymore - it just wasn't fun..... In fact, I had to resort to DSP trickery to make it listenable...
only after I run into horrible problems with 'old' foobar (finding out that some things even made it 'not bit-perfect') did I find out that many people are not that happy with ASIO in general (Peter being extremely vocal on the subject Happy ) and did I learn about WASAPI so i decided to finally give 'new' foobar a try...
unfortunately, it just did not work very good in my setup: I had to increase all buffers to maximum and still I would get pops/clicks randomly... then I again bumped into this vocal guy Peter who on some forum provided an explanation (or at least a very plausible theory for this: 'shared' vs 'exclusive') so I decided to try his XX which, quite frankly, looked pretty clunky compared to other audio players (no offense Peter) but, hey, in the end it's only important how it sounds.... which, btw, was another thing I had to get over, as, in theory, a software player should not have a big influence on sound quality: after all, 'bits are bits'....(yeah, right)
well, I'm glad I did try it and I promptly bought it: it truly is a class above any other player out there... (and I did try a lot of them...)
I am still in the mode of re-defining my reference points and did not have time to try playing with Q1 and other settings at all (just running 'unattended') so I will stop here but suffice to say that XX achieved the most important thing: music is again fun and it makes you want to listen more & more & more and then, some more.....
Josef
« Reply #21 on: March 28, 2009, 10:28:52 pm »
>600 or 700 gigs
that's going to take a while...
before you start copying everything, and perhaps to help others who might need this, you can check if registry setting is being applied with 'dir /X': that should show both 'normal' and 8.3 filename (if it exists) in dos prompt...
« Reply #22 on: March 28, 2009, 10:37:42 pm »
Thank you for all the kind words Josef ... Appreciate it.
The least I learned from this is that I can check for that Registry entry to be 0 ... (or to be non-existent I think, will work that out).
It is indeed great that we can work this out together with a dose of non-ignorance.
wub
« Reply #23 on: March 28, 2009, 10:51:23 pm »
you hit m right on the spot there josef
my story is exact the same
how can we make it sound like an LP with the dynamics of CD
no listen fatiqueness that is what ist all about tongue2
grtz
« Reply #24 on: March 30, 2009, 07:46:26 am »
G'day Peter,
I have a confession to make ... for quite a number of versions now ( at least as far back as 0.9w-7 and probably much much earlier ), whenever I access albums across my LAN I get the following message windows:
ChangeWP ~ Error 00: startIndex cannot be larger than length of string. Parameter name: startIndex
followed by ..
ChangeWP ~ 1720:DATA:\\MUTHA\Data_1
Those two error windows come up for each track played, and left unacknowledged simply cascade upon each other.
The playback is fine, and the artwork shows up in the appropriate panels within the GUI, but no wallpaper change occurs as you would expect. Those same albums played on the local PC behave normally.
The fact that no-one else had brought this to your attention had me thinking it was unique to my LAN environment here and I have been trying to figure out what might be causing it here. I've run out of ideas though, and with recent discussions about ChangeWP thought it time to mention it.
If anyone else runs a LAN at home could you try playing an album from across it and see if it works for you.
I should also add that even under the XP partition of my main music server ( dual boot ) I get similar messages ( although the "1720" is a different number then ) when accessing across the LAN.
Perhaps the impending 0.9x-6 fixes this ?
Do you want some logging done Peter?
« Reply #25 on: March 30, 2009, 08:06:13 am »
No, I didn't know about those errors. unhappy
Ok, you are using a drive letter ?
Indeed a logfile helps here, because then I can see how it originally looked like. No big deal, just press play briefly. Also the X3 file please.
And ... thanks.
« Reply #26 on: March 30, 2009, 08:50:10 am »
And ... thanks.
The following logs are the result of playing a single track from one of my LAN PC's called 'BURNA'.
To access the album, I went via the 'Library' button to the left of the 'Play' button and navigated to the album, then chose a single track.
The second error window had a "1626" in it at the front this time.
After getting the first set of error messages I stopped XXHE, and then restarted it again, but this time accessed a different album on another PC on my LAN called "MUTHA".
Hope you can follow this.
Not sure what you mean by 'drive letter'. My network shares mostly have a name of some sort for them rather than a plain letter.
Thanks Peter,
* X3-20090330-173639.log (0.89 KB - downloaded 533 times.)
* XX-20090330-173626.log (9.21 KB - downloaded 511 times.)
* X3-20090330-173815.log (0.89 KB - downloaded 529 times.)
* XX-20090330-173734.log (15.31 KB - downloaded 522 times.)
« Reply #27 on: March 30, 2009, 09:23:43 am »
Yep, I've already seen it.
But don't you recall you had a problem with that long ago, and that the solution was in the area of a drive letter ? or was it just another name ? or a name without spaces ? there was something ...
Anyway, I think this is solveable, because the most important is that the Short Names are worked out properly. Only the part of the Share Name is not, but I can attack that myself I assume.
« Reply #28 on: March 30, 2009, 10:30:17 am »
My problem eons ago was due to using spaces in the share name and I haven't been using spaces since. I seem to recall it was accessing the albums via that 'library' button also. I haven't tried simply dragging and dropping into the playlist .. perhaps that might show different results. Will try later.
The fact that it happens across my whole network and using different PC's to initiate the play process suggests its systemic to my LAN.
There's no urgency on this one Peter. Work on it when you can. I've been living with the bug for many a month now and I don't access the other PC's too often these days, but it would be nice to get it fixed as It might offer some alternatives for data storage.
« Reply #29 on: March 30, 2009, 11:21:58 am »
Will try later.
No no, not necessary.
But I think you are :  Happy
\\BURNA\Data (D)
Between Data and (D) is a space ...
But don't change it, I will just solve it. I hope.
Pages: 1 [2] 3  All
