April 20, 2025, 05:15:28 am *
Author Topic: Big problem 0.9x-5  (Read 20968 times)
mikelm
« Reply #15 on: March 30, 2009, 05:30:18 pm »
Hi Peter - just to say I am getting this problem occasionally also - sometimes after 1/2 hour of use, for no apparent reason, the screen starts to flash on & off, I loose that task bar and just after that I invoke a window inviting me to check for sony / vista upgrades !
As yet I still am not sure the benefit this hotkey thing gives - is that covered here somewhere ?
From my side I would prefer it if XXHE did not interact with the display at all and would be happy to be able to disable this function - is that possible ? at least until it's stable - just the XXHE window is fine for me.
cheers
mike
HP pavilion media m7680n dual core dual HD PC, Windows 7 Home Premium, Buffalo Sabre DAC with heavily modded supplies and discrete component op amp o/p stage, Caddock TF0202 & variable LDR volume control, Modified SKA amp, Jordan JX92S full range drivers with ribbon tweeters & stereo Subs
« Reply #16 on: March 30, 2009, 06:09:49 pm »
G'day Mike,
If you take the tick OFF the boxes for OSD & Unload Services in the settings menu, and make sure you don't load the AutoKey application, you should have an environment as you desire.
Give that a try.
and welcome aboard the geek train  Happy
mikelm
« Reply #17 on: March 30, 2009, 07:26:56 pm »
Thx Russ,
Just now the only box I have ticked is tool tips - I'll let you know what happens - but I have the feeling there's more to it than that
cheers
mike
