April 19, 2025, 11:28:47 pm *
Author Topic: Big problem 0.9x-5  (Read 20952 times)
leifchristensen
« on: March 25, 2009, 08:54:19 am »
hello P
I have severe problems with both 5 and 5b ; they end up not working at all and I went back to 4
could not get taskbar up again whatever I clicked and finally machine does not accept playing with 5 or 5 b
even after several restarts they don´t work
got fed up,have not got time for this,sry
4 is ok as long as I have q 2&3 to 17.
wait for next version
best
Leif
« Reply #1 on: March 25, 2009, 09:03:28 am »
Hi Leif, sorry to hear about that. But can (could Happy) you bring XXHighEnd forward by means of Alt-X ?
leifchristensen
« Reply #2 on: March 25, 2009, 02:16:37 pm »
hello P
will try this weekend
by the way
will attend to this on friday
Hans Theessink & Terry Evans
will probably be good
best
Leif
leifchristensen
« Reply #3 on: March 26, 2009, 09:46:24 am »
tried again y-day evening also with help from my son and we could not make 5 start at all :
xx window flickers as usual,but bar at bottom does not move
have tried with and without hotkeys installed
first time I tried it worked,but never after?
back to 4 and all is well
best
Leif
« Reply #4 on: March 26, 2009, 11:26:35 am »
Leif, please do this :
In your 0.9x-5b folder, there will be a Librarydata.txt file. Throw it out.
There will be a Favorites.txt. Throw it out.
A !Played.plxx. Same.
A !CurrentlyPlaying.plxx. Ditto.
Remark : I am not sure right now whether all these files are just visible, and they may show only when you have set hidden files to show.
Now, I don't want you to get into too much trouble, so you could just leave it to this, or throw out the files you indeed can see.
I may even be forgetting one or two ...
The next version will contain some kind of emergency thing that does it for you. So you might wait for that if you want.
sorry
leifchristensen
« Reply #5 on: March 26, 2009, 11:28:05 am »
I´ll give it a try 2nite to honour your effort to help! Happy
best
Leif
« Reply #6 on: March 26, 2009, 12:06:59 pm »
hey,
i had the same problem
it helps deleting those files
grtz
leifchristensen
« Reply #7 on: March 26, 2009, 01:13:05 pm »
ok good
best
Leif
« Reply #8 on: March 26, 2009, 01:38:06 pm »
Great. And AUDIODIDAKT, thanks.
As said, I will build in an emergency procedure for things like this (never had it myself though, but I know from other users it can occasionally).
leifchristensen
« Reply #9 on: March 26, 2009, 09:27:29 pm »
sry doesn´t change anything and when trying to play the currently plxx is replaced by a new one
bar doesn´t move though
best
Leif
« Reply #10 on: March 26, 2009, 10:21:33 pm »
Sorry Leif. I don't think I can get what you mean. But I will make that emergency procedure. Ok ?
Edit : Yes, the !CurrentlyPlaying.plxx is always replaced by the, well, currently playin Playlist. The question for the removal of it was just becasue it may cause anomalies by itself. After removing it, and that doesn't help, it's not the problem.
I merely suspect that you are dealing with the problem here : Re: Spdif digital out only???. My advice : wait for the next version (although the solution most probably is in the post I just referred to).
Thank you for your patience. yes
leifchristensen
« Reply #11 on: March 27, 2009, 06:57:36 am »
U2
patience is normally not my specialty Happy
2nite is Theessink so nothing will happen will the stereo
have a nice day; I most certainly intend to. Wink
best
Leif
« Reply #12 on: March 27, 2009, 07:59:25 am »
I think it will be good !
Don't forget to rip their new album from them (not released yet). I guess they'll have a bag of 'm somewhere hidden back stage.
leifchristensen
« Reply #13 on: March 27, 2009, 09:11:31 am »
If I get it I can send a filemail to you Happy
best
Leif
« Reply #14 on: March 27, 2009, 09:17:39 am »
ISN'T IT GREAT FILEMAIL.COM ok
