April 20, 2025, 05:01:08 am *
Pages: 1 2 3 [4]  All
Author Topic: Spdif digital out only???  (Read 47809 times)
« Reply #45 on: March 30, 2009, 06:49:26 pm »
With internal sc enabled:
This looks like it's all working now... for the FF800 at least.
Should we start using this Engine#3 now? Will the logs automatically write over each other?
* test01_internal_sc_enabled.log (0.66 KB - downloaded 547 times.)
« Reply #46 on: March 30, 2009, 06:54:39 pm »
Ha, great !!
Yes, you can keep on using that XXEngine3 version. Yes, the logs will over write eachother each time you press play.
But I will try to put up a 0.9x-6 tonight with everything in there. So for others, don't bother for now.
Thank you Mani, you were a great help, as usual ...
tricka
« Reply #47 on: March 30, 2009, 10:23:51 pm »
Hi Peter
all fixed - juli plays when selected with HDMI enabled - DAC test below.
I'll post logs if any more issues.
Thanks
Andrew
* X3-20090331-071820.log (0.76 KB - downloaded 552 times.)
* X3-20090331-071822.log (0.74 KB - downloaded 562 times.)
* X3-20090331-071824.log (0.74 KB - downloaded 546 times.)
* X3-20090331-071826.log (0.74 KB - downloaded 555 times.)
« Reply #48 on: March 30, 2009, 11:35:50 pm »
Andrew, Good !
The early night really did well, right ? heat
tricka
« Reply #49 on: March 31, 2009, 12:36:28 pm »
Yes Peter it did! Another one tonight. Happy
Really OT now (sorry) but after discussions with Russ this afternoon (and his invaluable help in setting up the hot keys and library gallery thankyou  Wink) I see why you have set it up as you have. At first glance it is abit counter intuitive...but with sound like this who cares about minor inconveniences like organising a gallery.
The SQ with services stoppped is >>> than without Grin Grin
And I rather like setting a playlist to play and sitting back - it's like playing an LP.
I experimented with all sorts of q's etc and find in my system (Juli (latency= 48) spdif out to the Ergo-HD650's at the mo) I like your set up of Q's=4,0,0,0,0 Scheme 3. Having said that it all depends I suspect on your DAC and how it interfaces.
I'm interested in your I2S interface...I wonder how you did that.....hmmm.
Thanks again Peter and at my end Russ!
Andrew
