April 20, 2025, 12:14:36 am *
Pages: 1 2 [3] 4  All
Author Topic: Spdif digital out only???  (Read 47801 times)
« Reply #30 on: March 26, 2009, 10:19:17 pm »
Leo, believe it or not, but I can't stand that mixer. If something has to be setup, something new, I ask my wife. Does this mean women logic is required here ? maybe. But I can hardly ever make sense out of it. Sorry ...
Just try it out; Explain how things work, and let her choose a box. Overhere that works ...  too much ! too much !
Leo
« Reply #31 on: March 26, 2009, 10:25:11 pm »
I will try this very worthwhile and insightfull suggestion yes
« Reply #32 on: March 27, 2009, 02:05:03 pm »
Any news on this one ? http://www.phasure.com/index.php?topic=775.msg5723#msg5723
Thanks.
tricka
« Reply #33 on: March 28, 2009, 07:11:17 am »
Hi Peter
I am awaiting the Juli before trying further with XX High End.
The onboard chippy is just too flakey to bother with - I have a suspicion the latest Vista drivers are just vista compliant drivers so can only really run AE2 with any success - which is about the same as native vista to me with the onboard chippy so no advantage there. Occassionally I get AE3 but it is flakey. The patch E3 file made no difference.
Interestingly I have been playing with linux mpd server ware and sonata front end with great success. It really is a great audio player as well. Plus a great benefit of linux is you don't have to do flips and twists to get close to zero cpu etc load.
What I look forward to is comparing XX High End w/linux mpd etc.
Andrew
tricka
« Reply #34 on: March 30, 2009, 03:56:30 am »
Hi mate
righto - I have 0.9x-4 installed and working in exclusive mode with the Juli@ over spdif to the Ergo. No problem at all with the right drivers installed. Now just the usual spdif issues ha ha. Sounds very good however.
I 've had a play with 0.9x-5b - it's a no go without disabling the onboard s/c in the bios (which is a nuisance as we use the hdmi out for the telly at the moment). That is XX High End defaults to the HDMI out when plugged in regardless of what is selected.
Andrew
« Reply #35 on: March 30, 2009, 07:17:21 am »
G'day Andrew,
which drivers are you using for the Juli@ ?
I had been using v1.04 for months and I noticed a few days back that there was v1.05 recently released. I have been using the latter for a few days now with no ill effect. Couldn't find any doco on what the new version brings forth but 'generally' a later version should be more stable.
I also have a hdmi device available ( via the video card ) but have no issues playing 0.9x-5b. Have you tried disabling your HDMI entry in the drivers manager ... that's what I have done. Even with it enabled I can choose the Juli@ SPDIF entry in the output setting of XXHE.
I presume you have the "Digital Output Device (SPDIF) ~ Juli@ Audio Working" ticked in the Sound/Playback from within your Control Panel? While checking the latter, check that when you highlight the Juli@ SPDIF entry and choose 'Properties', that under the Supported Formats, you have all sample rates ticked, and that under the 'Advanced' tab, you have ticks in the Exclusive Mode options.
Can't think of anything else at the moment that may be preventing 0.9x-5b from working.
« Reply #36 on: March 30, 2009, 07:54:54 am »
Andrew, can you show me the test01.log file then please ?
(http://www.phasure.com/index.php?topic=775.msg5723#msg5723)
tricka
« Reply #37 on: March 30, 2009, 12:00:44 pm »
Hi Peter & Russ
right-ee-oo....0.9x-5b all up and working: thanks  clapping clapping clapping
I installed 1.05 straight away as it is their sp1 driver (I think).
The trick was to disable the HDMI then make sure i had all the formats ticked (whoops - only 48 was!) then no problem. I'm just running through a bunch of test tracks now to test all the 16/44 - 24/96 range and so far no problems.
Ummm Russ...how do I get the HDMI back on...we use it at the moment for the telly ---it's disappeared from sight.
Ta muchly
Andew
ps Peter do you still want logs or only if something plays up??
« Reply #38 on: March 30, 2009, 12:17:43 pm »
hmmm ... it might be as easy as flipping a registry entry OFF and ON , and if that's the case a batch(s) job with a shortcut(s) on your desktop could be created to facilitate that.
I have no need for HDMI currently as I said so I had it DISABLED in the drivers manager section, but even with it ENABLED XXHE worked fine. It seems to me that your onboard S/C HDMI component works differently to the one here on my video card ( an ATI HD3450 ).
I'll see if I can see where in the registry things get changed when the HDMI driver gets ENABLED/DISABLED. Could open up a can of worms though .. hehe
« Reply #39 on: March 30, 2009, 12:33:28 pm »
There is a squillion references to the HDMI device in the registry and I'd be kidding myself if I could determine how they all interact.
My advice would be to toggle the device ENABLED via the normal Computer Management/Device Manager route per normal when you want to watch TV, and DISABLE it the same way when you want to listen to XXHE, although I'm not sure why you can't chose the JULI@ SPDIF in the output settings. This should work in the interim until a better process is worked out. Don't suppose your video card has HDMI perchance ?
« Reply #40 on: March 30, 2009, 12:38:57 pm »
Well, by now you guys are more experienced on it than I am, and it looks like HDMI is special somewhere ?
So yes. I need to see whether I internally don't deal correctly with the selecting of that device or whatever it is that happens. If you look at that log file yourself you'd see that nothing much is in there, but it should at least show which device *I* select. So, if that is the correct one, it can only be mr Gates doing it to you. So, no matter you have work arounds by know, I want to be sure it is not me.
If you send it, please tell accurately which device you selected from XX.
Thanks ...
tricka
« Reply #41 on: March 30, 2009, 01:19:39 pm »
coolio  Wink
Oh silly me ...I just enabled the "show disabled devices" on the playback devices and up HDMI popped...easy peasey.
I've attached 2 failures with the HDMI enabled and one success with the HDMI disabled (I think...it's getting late).
Awesome sound quality I am getting through my HD650's - zero noise floor  Wink; exceptional particularly on a cpu/ram hog like Vista: I like it best with services disabled and a low Q1 (although makes it a tad unstable).
Latency doesn't appear to matter so much for playback (to me). 48 induces a lot more cpu load etc than 256 so I figure it's much of a muchness.
Well done Peter...you Sir are a veritable genius thankyou.
Russ..mine is an onboard 3200 chippy with integrated hdmi.
Really in a week or so when my stereo is up and running again I won't need the HDMI any way.
Andrew
ps .9-05b sounds better than .9-04 to my very junior XX High End ears...
* X3-20090330-221559.log (0.74 KB - downloaded 574 times.)
* X3-20090330-220922.log (0.74 KB - downloaded 570 times.)
* X3-20090330-221524.log (0.74 KB - downloaded 580 times.)
« Reply #42 on: March 30, 2009, 01:28:49 pm »
It is getting late ? come on now ... Happy
Anyway ... these are not the test01.log files I wanted ... sorry ...
Again, in this post there's a new XXEngine3, and that will produce it. Install it over your current 0.9x-5b folder and press play briefly for the selected audio device. The test01.log will be in your current XX folder then.
Here : http://www.phasure.com/index.php?topic=775.msg5723#msg5723
whistle
« Reply #43 on: March 30, 2009, 06:32:47 pm »
Here's my Test01.log file (with my internal SC disabled).
* test01.log (0.53 KB - downloaded 586 times.)
« Reply #44 on: March 30, 2009, 06:40:41 pm »
Hey, thanks Mani. But this is just working correctly, right ?
Now what about when the internal SC is *not* disabled ... Do you still have problems ? if yes, I wish to see the test01.log from *that* !
Sorry to be a pain ...
