November 23, 2024, 06:32:43 am *
Pages: 1 [2] 3 4  All
Author Topic: Spdif digital out only???  (Read 46643 times)
tricka
« Reply #15 on: March 25, 2009, 10:33:32 am »
yup
have a look here: http://www.rme-audio.de/en_products_hdsp_pci_interface.php
gosh back to prob's tonight - no issues with engine 2 - runs the Ergo easily...but average sound quality. Having a nightmare with the 3....funny was working A -OK last night.
Might be time to get a RME 400 and be done with it...
The Engine 3 is what I am after.. Happy Happy
« Reply #16 on: March 25, 2009, 11:11:00 am »
That is not a PCI interface card ... it is a DSP (Digital Sound Processing) system which outputs its data over normal Firewire cable. This is indeed no Firewire protocol ("Cardbus" instead). But what to do with it ? nothing ... Happy
But what happened to your Engine3 stuff ?
tricka
« Reply #17 on: March 25, 2009, 09:26:41 pm »
dunno.....just stopped working
I mucked around with Vista yesterday trying to tidy it up ...so that will be the problem for sure.
Is the FF400 that much better than a Juli@ for transport duties?
Thanks
Andrew
« Reply #18 on: March 25, 2009, 11:26:00 pm »
Honestly ? I don't know. What I do know is that I am using it right now for other reasons (never mind which) and net I am very satisfied with it.
I also know that - coincidentally - Russ is using it, which btw is one of the reasons I dared buy it in the first place. So ...
So this indeed is an internal (PC) soundcard, but right now it is my choice. Maybe the FF does better, but keep in mind the price tag. Remember, I have both, and I still use the Juli@. No warranty for you because I use it differently, but the "PC noise" which would come from it, does not bother me. IMHO it is not a big deal to try it for 120 euros (a FF400 is a 1000 more).
YMMV.
tricka
« Reply #19 on: March 26, 2009, 02:17:25 am »
Yup you are quite right
If Russ recommends it that is good enough for me. I've just bought one. Should have it in a day or two.
Thanks
Andrew
« Reply #20 on: March 26, 2009, 09:16:21 am »
The solution was to simply disable the in-build soundcard (there seems to be a conflict going on here).
Andrew, have you tried disabling your internal SC? Before I did this, I couldn't get my FF800 to work properly with XXHE 0.9x-5b.
Peter, as I mentioned before, there is something weird going on here. Without disabling the internal SC, even when 'Speakers RME Fireface800' is selected, the signal is passed to the internal SC. Selecting any of the other RME outputs work fine, just not 'Speakers RME Fireface800'.
« Reply #21 on: March 26, 2009, 11:39:04 am »
Hmm ... scratching
Mani, what does the DAC Test show for sound device on the second line of the report ?
FYI : Selecting the sound device for Engine#3 is just new, and things may be wrong.
On quite some other note (but maybe not) ... I now see that I don't have Speakers for the RME. I only recognize them from XP drivers ...
See below. It should be Aanalog etc. ...
« Reply #22 on: March 26, 2009, 12:37:50 pm »
OK, so here are some images:
1) my devices
2) my XXHE settings
3) DAC Test with internal sound card DISABLED
4) DAC Test with internal sound card ENABLED (note: I have NOT changed the settings in XXHE - I still have the RME chosen)
With the internal sound card enabled, XXHE stops recognizing the RME (but it is still set as the default in Vista). If I play a track, it comes through my internal speakers.
Weird, no?
« Reply #23 on: March 26, 2009, 12:43:12 pm »
Sorry, last image is wrong - this was the result after enabling the SigmaTel, but before rebooting.
After enabling and rebooting, this is the result. Again, the RME is still selected in XXHE settings.
« Reply #24 on: March 26, 2009, 01:51:52 pm »
Yup, that would be my fault. I don't know how or what, but it must be.
Thanks.
And Andrew, SORRY ! you will be dealing with the same problem I suppose.
I still wonder where you get that "Loudspeakers" from. Mani, this might be related to your HDCD culprit thing ?
You are using recent drivers of course ? (like not over 2 years old swoon)
« Reply #25 on: March 26, 2009, 02:04:51 pm »
No, nothing to do with HDCD - I'm using just the FF800 as the DAC in my system 1).
My system 2) will use the Weiss AFI1 when I get it next week and feed my HDCD-enabled DAC via dual-wire AES/EBU.
I'm using pretty recent drivers from RME (v2.91 from 31/10/08) and my Vista is bang up to date. I'll try the latest RME drivers (v2.95) over the weekend, but I can't see that they will make a difference.
« Reply #26 on: March 26, 2009, 02:31:59 pm »
Nah, don't bother. My drivers are several months old by now.
My Vista is still SP0 though. So possibly *that* has changed things. Otoh, it seems more logic to me that RME changed the names. That is, I guess that is where the are coming from.
Dunno. Will upgrade my own drivers which are from June 2008.
Anyway, the problem is on my part. I figure it is related to the " /" in Speakers / Headphones, knowing that " /" has a special meaning in the C language for strings, and the strangenesses I apply to get those names out from the one program to the other. Will fix it.
« Reply #27 on: March 26, 2009, 05:58:32 pm »
Upgraded to the January drivers (and 2.70 firmware), and ... hey, I do have loudspeakers.
I wonder where they sit. Happy
Maybe the monitoring stuff.
« Reply #28 on: March 26, 2009, 07:42:31 pm »
For those who want to help and try (and have the problem) :
Below is an XXEngine3.exe. Save you old XXEngine3.exe (e.g. rename to .old), and unzip below zip to your current 0.9x-5b folder.
Please try whether the Device Selection now works properly. It should.
If not, please post the test01.log file which will be your the current 0.9x-5b folder. Note that this log file will be overwritten at each attempt of playback.
Note that you cannot see this is a new version. Only the file date/time denotes it.
Thanks a lot,
* XXEngine3.zip (60.65 KB - downloaded 551 times.)
Leo
« Reply #29 on: March 26, 2009, 09:03:53 pm »
I have not followed this thread too closely but if the question is can I select another than the default sounddriver it seems to work for me. If my rme spdif is default I can make it work with another driver i.e. rme speaker.
However I have not found how to get RME spdif producing any sound, this is not related to xx I think, just finding out how to select this within the RME software. It was allways RME loudspeaker for me. ANy tips on the settings for the RME mixer ?
Leo
