April 06, 2025, 05:26:49 pm *
Author Topic: Windows Start icon on screen in XXHE 0.9x-5  (Read 23634 times)
« Reply #15 on: March 23, 2009, 08:08:15 am »
This is solved now in 0.9x-5b.
Seems to work as intended here now  Good job !
BTW .... if you _need_ to run something else while in this mode, you can still access your 'Start' menu by pressing the "WINDOWS" key on your keyboard. Normally located on the bottom left somewhere.
« Reply #16 on: March 23, 2009, 08:45:09 am »
Johan, although I never saw the combination myself, I learned that because of actually wrong settings I could do (like in 0.9x-5 actually happened) the PC is confused until a reboot. So, please reboot the PC (if you did not already), and try again. Do not run 0.9x-5 anymore, because it will destroy again.
Does that help ?
If not, I currently have no further ideas. scratching
Btw, it works at Unattended only, but I guess you know that.
Eric
« Reply #17 on: March 25, 2009, 11:03:34 am »
after finishing playing XXHE 0.9x-5b, the Windows Desktop is not returned to the original setup (looks like the same kind of problem as in 0.9x-5, not being fully fixed in 0.9x-5b).
I have to manually bring up the services again using XXHE Settings. This works fine, but IMHO should be done automatically.
If this is a known bug to you, I apologise for reporting it again.
BTW, I am totally in awe re. SQ. My reference tracks sound like heaven. Please don`t change that anymore !!!!!!!
Cheers, Eric.
« Reply #18 on: March 25, 2009, 11:12:20 am »
Do you mean the "Services" button doesn't do its job ?
Eric
« Reply #19 on: March 25, 2009, 11:33:12 am »
the Services button works fine, no problem there.
However, after completing playing an album. I exit XXHE. Now the Services are not automatically restored by XXHE. So, I do have to start XXHE again to use the Services button. Or, I have to use the Services button before I leave XXHE. In any case, it requires a manual action. I would expect XXHE to automatically bring up Services and return to the "normal" Vista desktop when I exit XXHE.
Note: I play unattended with wallpaper switched on. Important: I did not start AutoHotkey before I start playing, because I have no intention to interrupt the play.
When I do start AutoHotkey and I use Alt-x to interrupt and stop XXHE, the problem does not occur!!
Hope this helps,
Eric
« Reply #20 on: March 25, 2009, 12:01:18 pm »
Ah, ok. I know this problem is there, and this was at least one reason to put in that safety button.
I think I have currently solved it (for the next version), but it requires more testing to be sure. Btw, stopping playback with Alt-S (at Unattended) would incur for the problem also.
And no, the Services button is not needed in advance of playback. Note though (and this is the wacky think) that when playback starts, the current state of the services is saved, and it is restored to that state when XX is brough up again. Thus, once the services don't run (like in the situation you described) and you start playback, that not-running state is saved, and at a next normal bring up (like with Alt-X) will not run the services.
All would be 100% waterproof if I'd be allowed to always start the services when playback is not going on.
Which I probably will do ...
Or as I told earlier, make a setting checkbox per service (there will be more in the future).
