April 05, 2025, 10:43:35 pm *
Author Topic: Windows Start icon on screen in XXHE 0.9x-5  (Read 23613 times)
Eric
« on: March 21, 2009, 09:34:07 am »
re. Model 0.9x-5,
When I start XXHE with Show as Wallpaper and Stop Services ticked, there is still a small Windows Start icon in the lower left corner of the screen. Is this as designed ? I can start XXHE again through this Windows menu, so I do not necessarily need Alt-X, Right ?
Ciao, Eric.
« Reply #1 on: March 21, 2009, 10:35:53 am »
I also have the tiny START button segment remaining when the rest of the taskbar disappears. It's look is very basic and plain though, none of the colouring that is typical of a desktop theme.
Perhaps of note is that upon starting XXHE ( before any play functions are done ), the system tray disappears immediately from the taskbar. The system tray can be returned to normal by dragging the taskbar to double height. You can then reduce it to single height again.
Regs,
« Reply #2 on: March 21, 2009, 11:26:20 am »
About the Sytem Tray thing ... I will look into that. I thought it removed by bringing up the Taskbar, but apparently this happens in another stage. Thanks.
Then that Startbutton.
This is a most weird thing, of which I thought I has solved it. But apparently this is not the same for every PC.
So, no, it is not intentional that it stays.
Heck, although I had similar situations here, and knowing how much trouble it took to get it right, now I'm afraid I will never be able to solve it for an unknown situation.
What are your both exact OS versions ?
Hahaha, no, not in this situation.
« Reply #3 on: March 21, 2009, 12:14:25 pm »
Just plain 'ol Vista Ultimate 32bit edition and NO services packs have been installed.
I've tried different themes etc. to see if that makes any difference but hasn't as yet.
1280 x 800 desktop res.
I had already disabled a number of unwanted services as per the earlier thread ( mid last year I suppose it would have been ). Perhaps that is interferring with things.
0.9x-5 sounds great though   Happy
Eric
« Reply #4 on: March 21, 2009, 12:50:02 pm »
And I have Vista Ultimate with SP1 and all available updates installed.
In addition to unnecessary services, I also shut down my LAN connection before I start playing.
Eric.
« Reply #5 on: March 21, 2009, 12:50:19 pm »
Vista Business NO services packs.
« Reply #6 on: March 21, 2009, 05:40:27 pm »
After some listenings sessions with restarts of XXHE the start-button is disappeared.........and.......back again...
« Reply #7 on: March 21, 2009, 07:38:00 pm »
wacko
« Reply #8 on: March 21, 2009, 07:48:33 pm »
re. Model 0.9x-5,
Ciao, Eric.
I have this happening too.
see sig for sys link
« Reply #9 on: March 21, 2009, 07:49:17 pm »
Regs,
and this too.
Eric
« Reply #10 on: March 21, 2009, 09:31:47 pm »
after having played an album (or a track), I close XXHE and apparently the (stopped) services are restored. I am now back on the desktop. However, something has changed. The Windows Start button has changed to a different icon, and also the whole look and feel of Vista is different. Looks like also the resolution has changed. I hope that this description helps you to find what goes wrong and to fix it.
Cheers, Eric.
« Reply #11 on: March 22, 2009, 07:11:46 am »
I know what you mean Eric. In this case things are just not restored. Try the Services button and you will see. Or ?
It can happen, however, that the start button stays strange. I had that too when it wasn't working here. A reboot solved that at the time.
But this is not the intention of course.
Grrrr
« Reply #12 on: March 22, 2009, 07:44:36 pm »
This is solved now in 0.9x-5b.
« Reply #13 on: March 22, 2009, 08:29:25 pm »
Also in version 09x-5b i don't need Alt-X.
« Reply #14 on: March 22, 2009, 09:54:51 pm »
So you have everything but the Start Button ? swoon
Did anything change for you compared to the original 0.9x-5 ?
