April 05, 2025, 06:40:54 am *
Pages: 1 [2] 3  All
Author Topic: .9x-5---No Sound  (Read 31055 times)
« Reply #15 on: March 22, 2009, 11:26:40 am »
Will do, except I do not know how to run a dac test nor how to get the "report". Am able to learn with a little help. Thanks!
« Reply #16 on: March 22, 2009, 11:29:20 am »
After some soundcomparisons between XXHE 09v-7, suddenly i have no sound again XXHE 09x-5.
Can anyone with the problem, please, ASAP run a DAC Test (not the Shared Mode one) and look whether the report coming from it indeed shows the Sound Device chosen at the top ?
for settings and dactest see attachments
* XXModeSupport.log (0.99 KB - downloaded 518 times.)
« Reply #17 on: March 22, 2009, 11:33:18 am »
Oh, I'm sorry.
In the Settings Area there is a "Dac is" combobox. Normally this should be set to what your DAC can dig. At the bottom is the one but last option "DAC Test". Choose that. Now play a 16/44.1 file. After a small minute a report shows up. At the second line the Sound Device is listed. If that one is not the one you chose, it is wrong. yes
Again, thanks.
« Reply #18 on: March 22, 2009, 11:36:12 am »
Ah Johan, thank you.
But is it correct or not ?
The output setting for me is always Luidsprekers(Prodigy HD2).
Luidsprekers (QVE for Prodigy HD2 (WDM))
I can't judge ...
Edit : Ah, it shows in the screen copy. So I guess it is not the same, right ?
Tony S
« Reply #19 on: March 22, 2009, 11:43:05 am »
I went back tried the .9x-5 version and the USB DAC (USB AUDIO DAC) came up as my chosen device but no signal to the dac but I was getting sound from the laptop speakers. I get no signal to the DAC no matter what device is selected.  Usually the PC volume control shuts off when the DAC is plugged in the USB port but aparently not with this version.
Vista Basic, Usb ->Musiland Monitor 02 -> Parasound Amp ->2.5 way Vifa/Scanspeak.
Ver. 0.9z-2, Playerprio-Low, Threadprio-Realtime, Buffer 256, 2x Upsampling, Adaptive Mode, Arc Prediction, Scheme-3, Q1- 1/10/10/0/0, SFS 70, Unattended, Services Off.
« Reply #20 on: March 22, 2009, 11:58:29 am »
In the settings area you can see Output Luidsprekers(Prodigy HD2). Something in the backgroud has changed this setting to Luidsprekers (QVE for Prodigy HD2 (WDM)).
After a reset the sound i back again. see dactest results
* XXModeSupport part2.txt (0.99 KB - downloaded 540 times.)
« Reply #21 on: March 22, 2009, 12:20:07 pm »
Okay, thanks to Russ am able to take screen shots; but can't figure out how to insert them here. Help...... Sorry. the pictures will make it easier to explain. When I hit the insert button it doesn't take me to explorer browser so I can select a picture. What to do? Again, am educable (but just barely!)
« Reply #22 on: March 22, 2009, 12:35:00 pm »
Will try to explain without pictures:
1. S/PDIF (Audiophile USB) was selected as the output device when I ran the DAC Test.
2. Second Line of DAC Test Report was: Line 1/2 (Audiophile USB) which is wrong. That is the Anologue output device.
3. 1 and 2 above were taken with .9--05. However same test taken with version .9--04 gave the following in the second line of the report: 04B2FCF0  (Thats weird because .9--04 works with engine #3.)
« Reply #23 on: March 22, 2009, 01:17:12 pm »
It is clear now without pictures. Happy But may you need them : At posting there's an Additional Options at the lower left corner. Click the + in front of it and a part with "Attach" appears. Click the "Browse" behind it, and from there you can select a before saved picture.
« Reply #24 on: March 22, 2009, 01:39:42 pm »
Again during sound comparison, i lost sound in 09x-5.
I deleted in Vista Sound the option Luidsprekers (QVE for Prodigy HD2 (WDM)) See attachment. Restart the system and again no sound. Did the DACtest again. Surprise...the output is now (SPDIF) (Prodigy HD2). For me its the end of 09x-5. Back to the privious version. too much !
* XXModeSupport part3.txt (1 KB - downloaded 553 times.)
« Reply #25 on: March 22, 2009, 02:24:09 pm »
Below is a new combo (0.9x-5a) XXHighEnd.exe - XXEngine3.exe. Unzip it over your current 0.9x-5 folder and let me know whether it helps.
It should ...
* XX-09-x5a.zip (534.48 KB - downloaded 543 times.)
Tony S
« Reply #26 on: March 22, 2009, 02:43:03 pm »
      The 0.9x-5a seems to be working now, I only had a brief moment to turn on the system and the DAC is getting signal now. I will have more time later to listen. Thank-you for getting it resolved quickly.
« Reply #27 on: March 22, 2009, 02:59:27 pm »
Thank you for your efforts Tony !
« Reply #28 on: March 22, 2009, 04:59:30 pm »
Just installed "5a" and all seems to be working. Will now turn my attention to the various sound options and will be back with a kazillion questions........  Happy Thanks!
« Reply #29 on: March 22, 2009, 05:17:27 pm »
For me it's the end of 09x-5.
........back again on 09x-5a with sound...so far.
First impression: is it possible that it sounds better than 09x-5? I've compared 09x-5 with 09v-7. In 09v-7 all the small detaills draw your attention. It give's a bigger involvement i think. More impact of the cymbals... The first soundwise impression of 09x-5a is good.
Pages: 1 [2] 3  All
