April 20, 2025, 06:26:34 am *
Author Topic: ShowCoverart error message about ImageSize.Height  (Read 10367 times)
Eric
« on: March 18, 2009, 06:56:24 pm »
I am getting the following error message when starting or stopping XXHE:
ShowCoverart
De waarde van 0 is niet geldig voor ImageSize.Height. ImageSize.Height moet tussen 1 en 256 liggen.
Parameternaam: ImageSize
When I click OK, the message disappears. It is not a drama, just a bit annoying.
I set the value for Width of Show Wallpaper equal to 800, this fits nicely to my screen.
I hope this helps,
Eric.
« Reply #1 on: March 18, 2009, 07:17:07 pm »
Hi Eric,
Can you please determine which picture this is about ? And when you did, can you see when something is the matter with it ? For example, it could be a non-.jpg (or .jpeg). But if you don't see something strange, can you post it as an attachment here ? then I can look at it ...
Eric
« Reply #2 on: March 18, 2009, 08:13:08 pm »
all my pictures are of type .jpg, and the errormessage occurs for every album or track I play. It happens regardless of the size of the picture (360x360, or 500x500, or larger).
The exact sequence is:
1) Start XXHE. If a picture of a previous session is still there, the error occurs right away.
2) Using Library, select a track and Play Unattended.
3) While playing, restart XXHE (to resume control) and the error occurs.
I hope this helps. Eric.
BTW it did not happen with previous versions of XXHE !
« Reply #3 on: March 18, 2009, 10:45:55 pm »
Eric, this happens for 09.x-4, right ?
I don't understand ...
Eric
« Reply #4 on: March 18, 2009, 11:03:30 pm »
Right, version 0.9x-4.
I must admit that I am not sure about 0.9x-3, but if you like I can run a test.
Eric.
« Reply #5 on: March 19, 2009, 04:04:20 am »
No, not necesssary I think. But you can do this :
Create another "music root" somewhere, and copy one or to almums in there. NOT those you are dealing with now.
Set the Music Root to that, and try. I am kind of confident that works.
Now copy in the albums you *are* dealing with at this moment. I don't say it will stop working, but it may, and this way you can find out which album is causing this.
And oh, please look in your current Music Root itself, because there too might be some "illegal" picture, causing it.
This is not a general error, and I didn't even have it a one single time.
« Last Edit: June 13, 2009, 04:37:52 pm by PeterSt » Logged
Eric
« Reply #6 on: March 20, 2009, 12:03:23 pm »
in version 0.9x-5 the error message problem is virtually gone. The message still pops up, but disappears again automatically in split second. I can live with that behaviour.
BTW: I followed your instructions with a new Music Root, and that seems to work too - in a way (sometimes I can recreate it, sometimes not - with the same track/picture). Weird.
Thanks, Eric.
« Reply #7 on: March 29, 2009, 05:12:43 pm »
Well, but the bug was still there I discovered myself. It is now solved in the next version (0.9x-6).
Btw it is the same bug as was reported here : 0.9x-3 -- minor bugs By Calibrator.
Thanks.
