April 06, 2025, 04:33:09 pm *
Author Topic: Setting Q1  (Read 7373 times)
Jon Ver Halen
« on: March 16, 2009, 02:02:37 am »
Hi Peter:
Hate to be a bother, but I can't seem to reset Q1.   Purchased and activated the software.  The Q1 slider is visible, and I can see Q1=14 just under the pause button.  But I can't "grab" the slider and move it.  Tried going to the Q control screen, and I can see and change Q2 through Q5, but there is no information in that screen regarding Q1.
Using the latest version 0.9x-4.
Jon
LydMekk
« Reply #1 on: March 16, 2009, 03:21:38 am »
Don't think you can use that under XP, only Vista.
« Reply #2 on: March 16, 2009, 09:05:42 am »
True. The only thing the demo version does not is Core Appointment and it won't output more than 100 items in the Library Area. Further differences are from XP/Vista (or better : not Engine#3 vs. Engine#3).
Day before yesterday  (at testing for you) I found that indeed those Q2,3,4,5 sliders can be moved in XP. Wrong ! They do nothing there. Btw, they may hence can technically, but I didn't create it so.
And thanks Jon !
Jon Ver Halen
« Reply #3 on: March 16, 2009, 07:45:49 pm »
Hi Peter:
I purchased, so the limitations of the demo version are not a problem.
So you really want me to move to Vista, don't you?  Seems like a lot is missing off the XP version.  Guess that is for another day.
Jon
Jack
« Reply #4 on: March 16, 2009, 09:16:56 pm »
You won't regret it.(soundwise. The rest is love or hate!)
Regards
Jack
